Revs increase dramatically
Postby Metalhead671 » Thu Feb 13, 2025 1:51 pm
Hi bought a 2018 transit from a garage with warranty included, had a problem with the axle which garage fixed but the van now revs from 2000-3000 when I depress the clutch and try to change gear, I know they have a rev holder but this jumps dramatically and stays for 2-3 seconds before slowly decreasing, doesn’t happen all the time but very frequent and in high gears mostly, had it back in at garage 3 times for problem but there not fixed it and told me this is normal and are basically washing their hands of the problem,
Metalhead671
Re: Revs increase dramatically
Postby DanMK7uk » Sat Feb 15, 2025 7:30 pm
Dont know a lot about the later transits, Id probably be looking at clutch position sensor..
Id not want my van revving to 3k on a cold unloaded engine.
You might have to get Ford to look or someone who knows the vans well.
DanMK7uk
Postby dannykhouston » Thu Mar 06, 2025 5:24 am
This is a sudden RPM problem! Have you checked for vacuum leaks or throttle problems? Those can definitely cause unstable RPM and frequent misfires.
dannykhouston
Postby apjones21 » Mon Oct 13, 2025 12:18 pm
Hi. I have the same problem. Did you ever sort it? Thanks
apjones21
Postby knobby1 » Fri Oct 17, 2025 9:50 pm
dannykhouston wrote:This is a sudden RPM problem! Have you checked for vacuum leaks or throttle problems? Those can definitely cause unstable RPM and frequent misfires.
These engines don't run any vacuum....the inlet/manifold is always under a slight possitive pressure which increases as rpm and load increases.
