solar panel
solar panel
Postby Blue » Mon Feb 24, 2025 5:30 pm
hi - I'm considering my options for a solar panel for my conversion. Rigid or flexible? Does anyone have any useful advice / recommendations please?
Blue
Re: solar panel
Postby JohnStokes » Thu Mar 20, 2025 5:27 am
Blue wrote:hi - I'm considering my options for a solar panel for my conversion.poor bunny Rigid or flexible? Does anyone have any useful advice / recommendations please?
Hi! Both rigid and flexible solar panels have their pros and cons, depending on your specific needs and setup.
Rigid Solar Panels:
Pros: More durable, typically more efficient, and often come with longer warranties. They're a good choice if you have a flat, stable surface like the roof of a van or RV.
Cons: Heavier and bulkier, and installation is usually more permanent.
Flexible Solar Panels:
Pros: Lightweight, can conform to curved surfaces, and easier to install without drilling. Great for irregular or soft roof shapes.
Cons: Generally less efficient and less durable, with a shorter lifespan. They can also be prone to overheating, which may reduce performance.
If you prioritize durability and long term efficiency, rigid panels are a solid choice. On the other hand, if weight and adaptability are more important, flexible panels might suit your needs. Some people also opt for a combination, using a rigid panel for the main power source and a flexible panel as a portable or backup option.
JohnStokes
Re: solar panel
Postby Harvy » Thu Mar 20, 2025 9:18 am
I fitted 2 rigid solar panels to the top of my caravan a couple of years ago and they are pretty good for the price.
It was an Amazon purchase.
https://amzn.eu/d/ervytPL
I did have to buy a couple of other bits too. Including 2 big leisure batteries from Halfords.
2010 T350 LWB H3 RWD 2.4 115 Full poverty spec! :D
Harvy
Re: solar panel
Postby Radiofence » Thu Mar 20, 2025 9:39 pm
I got an eco worthy flexible. Cheap, 100 ah lithium battery abd discrete. In my opinion as long as it powers an electric blanket over night and a small peltier fridge in summer, I'm happy. If it stops working I'll glue another on top if I can rip it off.
Transit custom 2.2
Radiofence
Re: solar panel
Postby bortaf » Sun Mar 23, 2025 7:13 am
rigid every time for me, ive replaced a lot of flexi pannels on narrow boats they overheat then delaminate, rarely last more than 3 years if outside all the time, ect, ect :( if you have a roof rack system the install can be as uninvasive as a flexy install :D
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Re: solar panel
Postby Redvee » Tue Mar 25, 2025 11:48 pm
bortaf wrote:if you have a roof rack system ....
I was looking at fitting to a roofrack but the awning on the NS stops a roofrack being fitted but then I sawa van with a roofrack and the awning fitted to the roofrack legs.
Redvee
Re: solar panel
Postby Blue » Tue Apr 29, 2025 7:12 am
Thanks to everyone who replied. Your opinions have been very helpful in my decision making.
Blue
