BCM UNIT 2009 FORD TRANSIT DIESEL DUAL CAB UTE
Postby Brigalow » Tue Mar 04, 2025 11:33 pm
I have replaced the BCM 4 times in 6 months. Have checked all circuits found no faults. The last occassion was a brand new BCM from Ford Motor Company. The vehicle never got past the calibration stage before the CPU it fried . The technician said there was power backfeed from unidentifed source. Am at a loss as to what s the problem source. I am in Australia.
Brigalow
Re: BCM UNIT 2009 FORD TRANSIT DIESEL DUAL CAB UTE
Postby knobby1 » Wed Mar 05, 2025 10:20 pm
Brigalow wrote:I have replaced the BCM 4 times in 6 months. Have checked all circuits found no faults. The last occassion was a brand new BCM from Ford Motor Company. The vehicle never got past the calibration stage before the CPU it fried . The technician said there was power backfeed from unidentifed source. Am at a loss as to what s the problem source. I am in Australia.
If it is "frying" the BCM or PCM, there must be a short circuit in the system, full length of the wiring needs to be checked. BCM's and PCM's themselves rarely fail. If a short circuit is happening it should be blowing fuses. Obviously something strange going on.
Postby Altransit » Wed Mar 05, 2025 11:04 pm
knobby1 wrote: Obviously something strange going on.
Could it be a spike from the alternator? If a diode or two from the rectifier pack has gone down, it could be supplying A/C current, or "dirty DC", which electronic circuits don't like much.
Just an idea :mrgreen:
Postby knobby1 » Thu Mar 06, 2025 2:22 am
One would imagine it should still blow a fuse if over current or short circuit.
What sort of voltage do you have across the battery with engine running.
Postby Radiofence » Fri Mar 07, 2025 9:54 am
I'd suggest checking earth's to alternator/ engibe. And for the cost of it, fit a genuine alternator.
Transit custom 2.2
Radiofence
Postby Airthies » Thu Mar 13, 2025 9:11 am
Check main engine earth and earth at seat base.
I had a van frying PCM and BCM which I think was the engine earth but ended up swapping out all dash and engine bay harnesses anyway.
Hope you get to the bottom of it.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
