NO ACCELERATION ONLY GOING IN 1ST 2.2 2009 ford transit
Postby onken » Sat Mar 29, 2025 11:16 pm
BLUE SMOKE ONCE
STALLING FELT LIKE NOT GETTING FUEL
PRESS ACCELERATOR SILENT NOTHING HAPPENS RESTART AND IT GOES BTTER GETS REVS UP
COULD ANYONE ADVISE DOES THIS MODEL HAVE A CRANKSHAFT SWITCH ?
IM HOPING ITS SOMETHING AS SIMPLE AS THAT OR THE BLEEDING VALVE AND CHANGE OF FUEL FILTER?
OR A PCV VALVE?
WAS CONSIDERING PURCHASING A COMPUTER TO LOOK AT IT IM NOT A MECHANIC BTW I TAXI AND NEED VEHICHLE MOST MECHANICS BUSY WEEKENDS ACTUALLY ALL TIME :(
IS IT AN EC650 WHICH IN THIS VIDEO LOOKED GOOD>??
https://www.youtube.com/watch?v=RTAZNp513NA
OR MAYBE ITS A SIMPLIER DEVICE LIKE THIShttps://www.ebay.co.uk/itm/162068198073 ... 18&mkevt=1
OR MAYBE I NEED BOTH TO CONNECT? ..ANY HELP APPRECIATED GREATLY
onken
Re: NO ACCELERATION ONLY GOING IN 1ST 2.2 2009 ford transit
Postby metalworker0 » Sun Mar 30, 2025 5:31 pm
Sorry you cant do any diagnostics on these vans without a scanner, so you are going to have to check it over yourself, with a code reader / scanner
i suggest use forscan
NOTE: you can use forscan to get correct fault codes with proper explanation of them - a generic fault code reader may be somewhat misleading
Here on this site - They recommend "Forscan" which is FREE software that you download to a laptop..you buy the interface cable (of which you pointed out on ebay -- this is just the cable you need a laptop)
You can join the forscan forum ..again free, to get the software and more answers.
https://forscan.org/forum/
Postby knobby1 » Sun Mar 30, 2025 9:41 pm
onken wrote:BLUE SMOKE ONCE
OR A PCV VALVE?
You don't have to scream at us..!! :wink:
Would really help if you told us what model Transit you have..?? Mk6 or Mk7..?? FWD or RWD..?? TDDi or TDCi..?? Euro-3, 4 or 5..??
You need Forscan and a compatible cable.
All the info you need is here:
https://forscan.org/download.html
Postby vansit1 » Wed May 21, 2025 7:33 pm
any update?
vansit1
Postby knobby1 » Wed May 21, 2025 8:04 pm
vansit1 wrote:any update?
He hasn't been back since that very first post...I suspect we'll never know.
I find it strange that some people come on here looking for help.... and never return.
