MK7 rear right light out, bulb fine
Postby Z156 » Tue Apr 08, 2025 1:52 pm
Hi all, I have a transit MK7, mwb Hightop FWD, 2009.
I plugged a trailer in last night and the lights were all mixed up. After unplugging it I realised that the van's rear right tail light was out. The bulb is fine. What would the problem be? Do you think it's a blown fuse? If so which fuse would it be and where is it as I can't find any mention of a fuse for the rear right tail light or tail lights at all for that matter in any fuse diagrams I've found? All the other lights work fine.
Thank you,
Z
Z156
Re: MK7 rear right light out, bulb fine
Postby knobby1 » Wed Apr 09, 2025 8:31 am
Z156 wrote:Hi all, I have a transit MK7, mwb Hightop FWD, 2009.
Thank you,
Z
Probably a poorly earth in the rear cluster or the earth right near it.
Fuses are here:
viewtopic.php?f=40&t=49206
