I have tried disconnecting the battery and I have forscan but I still cannot get is started.
Simonmate2010 wrote:Hi all! I don’t normally post here but I’m desperateI fitted a prv valve and my engine was showing some imbalances and EGR fault so thought it might be due to rail pressure. Pulse width was low also. Now I ran a pump learn and it cut out but
now the van will not start at all! Does anyone have any idea?
knobby1 wrote:Simonmate2010 wrote:Hi all! I don’t normally post here but I’m desperateI fitted a prv valve and my engine was showing some imbalances and EGR fault so thought it might be due to rail pressure. Pulse width was low also. Now I ran a pump learn and it cut out but
Assuming you have a Mk7 Euro-4..?? You don't actually say what model Transit you have..?? FWD or RWD..?? 2.2 or 2.4..??
PRV doesn't control the rail pressure, it's just a relief valve and does nothing else. Was the new PRV a "genuine" Ford/Denso item..??
SCV controls the fuel rail pressure.
Is the fuel filter full..?? If not, refill it and try starting..
Disconnecting the battery does nothing except require you to reset the clock and radio code.
Have you replaced the EGR valve..?? They often play up/fail.
Simonmate2010 wrote:i have just tried to run the pump learn and it failed again - the engine is now starved of fuel again so assume that the filter is now low on fuel. would this be due to an air lock? do you think i should keep going until it gets through? the rail pressure is showing in range before i start the pump learn.
