Exhaust Gas Temp Sensors (2015 mk8 2.2 Euro 5)
Postby micmacdevon » Mon May 05, 2025 5:40 pm
Hi all
Can anybody give guidance on following please.
2015 mk8 2.2 rwd euro 5
Issues with dpf regeneration
Live data on a stone cold engine shows 63 degrees C on both sensor 1 (green) and 2 (blue)
I have tested with multimeter and there is no resistance (or continuity) on either when tested on its terminals.
Sensor 3 is showing 0.207 ohms on the 2k ohms setting of multimeter.
Ambient temp is approx 16C
Google AI says that these are NTC sensors and should show resistance.....but not sure this is the case ?
Should I assume that these sensors have been fried !? and need replacing ?
At £183 each from ford I want to be sure !!!!!
Many thanks.
2015 Transit Mk8 125 T350 RWD - Euro 5
2012 Transit Connect 1.8L Duratorq TDCi CR 90PS
micmacdevon
Re: Exhaust Gas Temp Sensors (2015 mk8 2.2 Euro 5)
Postby metalworker0 » Mon May 05, 2025 5:47 pm
why would it have three temperature sensors, i would have thought one was enough.
the others are maybe pre dpf and post dpf pressure sensors
and the temperature sensor ..i reckon it works same as K-type
no resistance - it makes voltage
from wiki
A Type K temperature sensor, also known as a thermocouple, works based on the Seebeck effect, which creates a voltage when two different metals are connected and exposed to a temperature difference. In a Type K thermocouple, the metals are Chromel (nickel-chromium alloy) and Alumel (nickel-aluminum alloy). When these metals are joined, and one junction is exposed to a temperature gradient (a temperature difference), a voltage is generated, proportional to the temperature difference. This voltage can be measured and correlated to the temperature using standard calibration tables or electronic devices.
Postby micmacdevon » Mon May 05, 2025 5:51 pm
Should add......
Live data shows both as having 4.995V on them.
Cheers
micmacdevon
Postby micmacdevon » Mon May 05, 2025 5:54 pm
metalworker0 wrote:why would it have three temperature sensors, i would have thought one was enough.
from wiki
Hi Mark
This has 3 on from what I can see.....
All 3 show on diagnostics
Bank 11 is pre dpf
Bank 12 is mid dpf
Bank 13 is post dpf
Cheers
micmacdevon
Postby micmacdevon » Mon May 05, 2025 5:56 pm
from wiki
Hi Mark
Bank 11 is pre dpf
Bank 12 is mid dpf
Bank 13 is post dpf
Cheers
There is a separate mid dpf pressure sensor around the other side......
micmacdevon
Postby metalworker0 » Mon May 05, 2025 6:06 pm
not owning a mk8 ...where is that device located ...if its right after the engine, its the catalyst not the dpf
Postby micmacdevon » Mon May 05, 2025 10:07 pm
metalworker0 wrote:not owning a mk8 ...where is that device located ...if its right after the engine, its the catalyst not the dpf
micmacdevon
Postby metalworker0 » Mon May 05, 2025 11:15 pm
think its maybe a combined catalyst and dpf - well on ford diagrams on cat-car its called a catalyst and particulate filter assembly
in ebay its just called a DPF
explains why so many sensors ..wouldn't like to replace it £££££££
Now wen have to work out if the sensors work like a K-type thermocouples..if so maybe barking up the wrong tree with Resistance measurements.
Postby metalworker0 » Mon May 05, 2025 11:30 pm
found this post about such a exhaust gas temperature sensor
First check continuity between the two wires of the thermocouple. If you have continuity it's probably fine. Usually they are either good or bad, but in rare cases they can be compromised by corrosion or something. To check if it's accurate you'll need a voltage meter than can read millivolts. Put the leads on each wire of the thermocouple. At 32*F the voltage across them will be zero. As temp increases the voltage goes up. 70*F will be .843 and 1000*F will be 22.251. I'll attach one of the standard voltage/temp charts for type K.
chart
https://www.ford-trucks.com/forums/atta ... download=1
chart is mind boggling --- like a bus time table for the whole of a county....im sure a simplified one can be found
Postby micmacdevon » Tue May 06, 2025 9:04 am
metalworker0 wrote:found this post about such a exhaust gas temperature sensor
chart
No continuity or resistance at all in the first two (1 & 2) sensors which makes me think they are fried/faulty. Will pop them out and do temp against voltage test .
Cheers !
micmacdevon
