Radiofence wrote:Turbo actuator is on same data line too I believe egr valve too.
Radiofence wrote:The new pipe has a mesh coating on and I'm guessing, is moulded slightly differently as its not as close to the bolt any more.
metalworker0 wrote:Have a look at the large rubber convoluted air pipe thing going from air box to turbo ..this could have splits in it ..this would not effect performance ..but could let in dust and grit
The boost pipes - it's common to have oil in them.may be a pile in the intercooler as well ..cleaning these, is or should be part of a service .
