Where is it leaking oil from?
Postby sythna » Thu May 22, 2025 11:41 pm
Transit MK7. Lost around 4 litres of oil in around 400 miles.its dripping quite quickly. Cleaned a bit with a hot jet wash but clearly missed some parts. I have made some videos without jacking the car up.
What do you think? Sump?
No loss in power, pulls and no smoke under 3.5 rpm.
See video
https://youtube.com/shorts/EJkAaqMrJ6s?si=73_BO8NE6Mlq-b68&utm_source=MTQxZ
https://youtube.com/shorts/LgYe-dUwWl8?si=hkq8Ag7WhWv2U-wX&utm_source=MTQxZ
sythna
Re: Where is it leaking oil from?
Postby andz327 » Fri May 23, 2025 12:15 am
Seems higher up than the sump
Is it wet around the injectors??
andz327
Postby metalworker0 » Fri May 23, 2025 4:13 pm
Dont know camera footage too wobbly and quick
For 0.5 seconds or there about, in the blink of an eye , - is that a turbo oil return pipe i see further up, oozing oil ..
Postby knobby1 » Fri May 23, 2025 9:00 pm
sythna wrote:Transit MK7. Lost around 4 litres of oil in around 400 miles.its dripping quite quickly. Cleaned a bit with a hot jet wash but clearly missed some parts. I have made some videos without jacking the car up.
Give the engine a good degrease and clean down...hose off, let it dry, start the engine, quick run around the block and the oil leak will then become obvious.
Postby Radiofence » Fri May 23, 2025 9:27 pm
You could also try illuminesant dye and a special torch
Transit custom 2.2
Radiofence
Postby sythna » Sat May 24, 2025 12:48 am
Thank you all. Will buy some cans tomorrow and hot wash with a smaller lance. I have dye as well but don’t have the yellow glasses which I am not sure if is needed. Bought another van near me as it was cheap but willing to get this fixed rather than making it someone else problem. My ethics won’t allow me.
I will report back with better, less wobbly slower videos.
Thanks again.
sythna
Postby sythna » Sat May 24, 2025 12:51 am
andz327 wrote:Seems higher up than the sump
They used to be but I post clean some weeks ago they are mostly dry with minimal oil around the seals. It’s somewhere in the middle and then I suspect it’s the oil sump as well as that’s usually very shiny and wet. Have eaten through 4 liters of oil in around 200 miles now.
sythna
