My Tranny has a stiffy....
Postby Radiofence » Fri May 23, 2025 9:32 pm
Going up the alps, gearbox fine, no whines etc. But gear shift started getting stiff. Even to wiggle it in neutral. Let it cool for a bit, was better, then returned. Let it cool completely (1hr) and it was loose as it should be. Strange.
2.2 14 plate custom. Recent gearbox oil (as I put new flywheel etc in)
Transit custom 2.2
Radiofence
Re: My Tranny has a stiffy....
Postby andz327 » Sat May 24, 2025 12:36 am
On mk7 where the selector shafts are exposed if you give them a good soaking with loose juice the some spray white grease used to sort this problem so probably worth a try with your custom
andz327
