Left lights on warning comes and goes
Postby metalworker0 » Sat May 24, 2025 4:29 pm
2006 1.8 transit connect.
About 6 months ago, the warning sound that i had left the lights on disappeared for about a week, then came back again .
Today it's gone again.
Where do think this fault is, where should i look first ..is it in the loom between door and A-post, or somewhere else.
Re: Left lights on warning comes and goes
Postby DanMK7uk » Fri May 30, 2025 5:11 pm
I assume there would be a switch somewhere when the door is open, i wonder if your switch is not happy ?
Just had a look on mine I cant see where it would be.
Door card off and have a look maybe ?
DanMK7uk
Postby metalworker0 » Fri May 30, 2025 7:08 pm
I was after a go-to answer
it would be something if i knew where the speaker was , that would be my first go-to.
Postby DanMK7uk » Fri May 30, 2025 8:23 pm
Pretty sure speaker is behind the cluster / clocks.
Logically the beep is activated when the door is adjar, as yours is intermittent id be first looking for the switch which activates the speaker. Probably sticking “door closed” position.
Speakers/ beeper unlikely the problem.
DanMK7uk
Postby metalworker0 » Fri May 30, 2025 8:42 pm
Does not happen when the passenger door is left open either, if it works that way that is.
Think its one of those Round-Tuit things.
Don't like taking door trims off, they usually break.
Will have to do it soon i think , as i'm having trouble with the locks, locking then unlocking, as well.
so maybe tomorrow ..or next week or next month :)
Postby DanMK7uk » Fri May 30, 2025 8:51 pm
metalworker0 wrote:Does not happen when the passenger door is left open either, if it works that way that is.
The passenger door won’t bring it on anyway.
Does the cabin light come on when the door is opened
Do you get the door ajar / symbol/ message on the dash ?
DanMK7uk
Postby metalworker0 » Fri May 30, 2025 9:10 pm
just looked, it has three positions ..only one works, that is permanently on , tried it with lights and ignition on as well.
the other two positions ..will assume one is permanently off , the other will be activates with door ..is that right...if it is like so, it rules out the speaker.
There must be some sort of switch inside the door like you said. ..probably hanging off or loose with the rest of the central locking stuff :)
Postby DanMK7uk » Fri May 30, 2025 9:37 pm
Id say so yes… (switch) there is your go to answer, Mark.
Hope you get it sorted with minimal aggravation.
Cheers
DanMK7uk
Postby Radiofence » Mon Jun 02, 2025 12:08 pm
I'd guess it's the loom at the door junction. Taking the card off is always a pain. Seems impossible to get genuine clips that tend to shatter.
The only positive is you can pretend you have a pet hamster on long journeys as the door card starts to squeak!
Transit custom 2.2
Radiofence
