Code P2599
Code P2599
Postby Billinavan » Sun Jun 01, 2025 9:37 am
Hi, I have a 2012 2.2 RWD transit MWB, over the last few days I have Engine Malfunction come up and the van goes into limp mode, as soon as I stop and restart it clears and runs fine again, scan with Forscan gives me this code with 'Turbocharger boost control position sensor 'A' stuck high. Im thinking this is the boost control on the side of the turbo and logic says its getting stuck?? Am I looking for physically stuck or is this likely to be the controller failed and need to be replaced, any input would be awesome.. Many thanks in advance, Bill...
Billinavan
Re: Code P2599
Postby knobby1 » Sun Jun 01, 2025 8:16 pm
Billinavan wrote:Hi, I have a 2012 2.2 RWD transit MWB, over the last few days I have Engine Malfunction come up and the van goes into limp mode, as soon as I stop and restart it clears and runs fine again, scan with Forscan gives me this code with 'Turbocharger boost control position sensor 'A' stuck high. Im thinking this is the boost control on the side of the turbo and logic says its getting stuck?? Am I looking for physically stuck or is this likely to be the controller failed and need to be replaced, any input would be awesome.. Many thanks in advance, Bill...
Could be a couple of things...EGR not happy, the actuator itself or its wiring not happy...or possibly the little hole in the inlet manifold where the MAP sensor gets it's sense pressure from, they block up with crud.
The throttle body can be a point of issue with the Euro-5's too. I'm still unsure of why they have them when all the earlier engines do not.?? :?:
Re: Code P2599
Postby Billinavan » Mon Jun 02, 2025 7:39 am
Hi, thanks for your response, I will check through the wiring connections today, one question, where is Turbocharger boost control position sensor 'A'? im thinking it is part of the turbo boost controller on the side of the turbo.. Thanks..
Billinavan
Re: Code P2599
Postby Radiofence » Mon Jun 02, 2025 12:34 pm
If it's got the electronic actuator, it could be that it's jammed as the cogs get worn and form a strange shape. But it's also on your egr valve line. Probably more likely the egr valve
Transit custom 2.2
Radiofence
Re: Code P2599
Postby Billinavan » Mon Jun 02, 2025 6:09 pm
Radiofence wrote:If it's got the electronic actuator, it could be that it's jammed as the cogs get worn and form a strange shape. But it's also on your egr valve line. Probably more likely the egr valve
Thanks, Iv checked through all the connections and the MAP sensor hole appears clear, did find the wiring for the turbo actuator was tight as routed incorrectly, will give it a drive and see what happens. It did have a replacement turbo last year but still the original actuator..
Billinavan
Re: Code P2599
Postby Billinavan » Mon Jun 23, 2025 7:23 am
So drove the van again and the same code came up with engine malfunction warning, as usual it clears at a restart, plugged in Forscan and found a reset fir the turbo actuator, ran this and the van has done about 80 miles without issue. Fingers crossed but if it happens again ill swap the actuator out for a new one..
Billinavan
Re: Code P2599
Postby Billinavan » Mon Jul 14, 2025 1:44 pm
Just to conclude this one, it did a few trips and then started beeping at me again, has a new actuator now and a few drives in and all appears to be good..
Billinavan
