Gearbox change wrong speed
Postby Bezerra » Sun Jun 15, 2025 5:57 pm
Hi guys,
Recently change my mk2 gearbox (4speeds) to a 4 speeds with overdrive.
Everything works fine but it shows wrong speed on the odometer.
Does anyone know what’s wrong?
Bezerra
Re: Gearbox change wrong speed
Postby metalworker0 » Sun Jun 15, 2025 7:00 pm
Think you are going to be changing this out
https://www.motomobil.com/en/products/g ... 149020-4-h
As you can see there are four different ones with different amount of teeth
The amount of teeth dictates ...what final ratio you have in the drive to the speedo
Which one / what that is? ...well you are going to have to do some more research.
Each different combination of gearbox and rear diff, requires a different speedo drive gear
To help you along
putting this into google
6014902 ford
Brings up the ford "zap parts site" in google. it brings page with with the gearbox parts list, one of the results has the over drive gearbox ..on the parts diagrams underneath. are the different ratios for the gearbox / diff combination..unfortunately it's in a foreign language and the google translate does not work on it ...and i cant get at this information from the english version .
Postby dumper » Mon Jun 16, 2025 6:51 am
Back in the day I fitted a few o/d boxes and changed dash to cortina one with clock in it used to do it by trial and error as the drive gears were available in breakers yards must have been the same gear type as in the 4 speed have you tried the drive out of your old box they are colour-coded so if they are different colours and still don’t work at least you’ll eliminate two from the list of available ones.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
