Please help...wont relearn anything on forscan
Postby royolsnail420 » Sat Jun 21, 2025 8:08 pm
2.2 85bhp fwd 2007can some one please help me... all injectors are good it won't let relearn anything because off the cylinder imbalance...would anyone know y this is.. appreciate any information
royolsnail420
Re: Please help...wont relearn anything on forscan
Postby metalworker0 » Sat Jun 21, 2025 8:51 pm
are you supposed to put into forscan, the injector code numbers, when you change injectors.
if so that would be a start
Postby DanMK7uk » Sat Jun 21, 2025 11:47 pm
What work have you done recently if any on the fuel system ?
DanMK7uk
Postby knobby1 » Sun Jun 22, 2025 8:19 pm
royolsnail420 wrote:2.2 85bhp fwd 2007can some one please help me... all injectors are good it won't let relearn anything because off the cylinder imbalance...would anyone know y this is.. appreciate any information
If the "new" injectors haven't been coded in...or they're not healthy, it will fail to initiate the learns or will fail part way through the learns process..
Has the SCV and/or PRV been replaced..?? If so, were they genuine Ford/Denso items.?? If not, you're wasting your time.
Postby MinorMatt » Mon Jun 23, 2025 9:53 am
knobby1 wrote:Has the SCV and/or PRV been replaced..?? If so, were they genuine Ford/Denso items.?? If not, you're wasting your time.
Or Peugeot/Citroen ;)
Postby knobby1 » Mon Jun 23, 2025 8:11 pm
I think the Nissan Navara/Pathfinder D22 also uses the same pump & SCV.
Postby royolsnail420 » Mon Jun 23, 2025 8:27 pm
Hi all thanks for your response bin working so not had chance to reply in depth
The pcv/scv they was working fine before turbo blew and are new from ford....I have changed all injectors seal with bolts and cleaned the injector holes this had sovled the blowing back abit, it's still there with oil still coming out exhaust that's one problem which is makeing me think I've fried a piston and still runs like there is a injectors down even tho they have bin tested... as for the injector coding it will not let me into the codes keeps saying I'm inputting in coreect codes even when i try and put the original codes back in i don't know if this is because in stupid and don't know what I'm doing or there's somthing wrong somewhere ......and it will not let me do a pump or pilot learn because off the cylinder imbalance which is showing
Cydlinder 1 ....-7.890
Cydlinder 2......-5.029
Cydlinder 3....16.417
Cydlinder 4....-5.350
I know I've read somewhere that these figures don't necessarily mean anything but its whats stopping me from doing any learns....
Any help is much appreciated and thank you for all your replies...
I'm trying to co
royolsnail420
Postby knobby1 » Tue Jun 24, 2025 2:43 am
royolsnail420 wrote:Hi all thanks for your response bin working so not had chance to reply in depth
I'm trying to co
Something drastically wrong there my friend. Ideally they should be zero but are ok if +/- 1.0.
Were the injectors "coded" into the PCM..??
