MK 4 Autobox won't go engage ahead gears.
Postby petethetug » Wed Jun 25, 2025 5:10 pm
Was ok on the night time. Next morning would go astern but not ahead.
Oil level seems ok.
Have checked the vacuum signal to the transmission, It is approx -0.580 bar at idle rpm and mor or less zero at full load.
Vacuum pump seems to be delivering about -0.8 bar at the supply end.
Any help or Ideas will be greatly appreciated.
Thanks, PTT.
petethetug
Re: MK 4 Autobox won't go engage ahead gears.
Postby metalworker0 » Wed Jun 25, 2025 8:34 pm
This any good to you
https://www.therangerstation.com/tech_l ... manual.pdf
