HELP! Mk7 2.2 abs/traction control fault....no codes!
Postby OmhMK7 » Thu Jul 10, 2025 7:10 am
Morning all,
I have a recently purchased 2013 2.2. Seems to have been looked after and hasn't missed a beat in the first week of ownership.
Jumped in it this morning to find both abs + traction control lights on and in limp mode. Ive plugged in a basic obd which is showing no codes at all?!
Any help would be greatly appreciated!
TIA!
OmhMK7
Re: HELP! Mk7 2.2 abs/traction control fault....no codes!
Postby metalworker0 » Thu Jul 10, 2025 11:26 am
You need a better code reader then
Forscan - that's what they recommend here .
NOTE: you can use forscan to get correct fault codes with proper explanation of them - a generic fault code reader may be somewhat misleading, or doesn't work
"Forscan" is FREE software that you download to a laptop..you buy the interface cable -- this is just the cable, you need a laptop)
You can join the forscan forum ..again free, to get the software and more answers.
https://forscan.org/forum/
Then you come here list the fault codes here ..and we will try to work out the problem.
