Specific ASM Problem
Postby Eagleman61 » Tue Jul 15, 2025 12:58 pm
Hi there, I am new to this forum and have being searching here for answers to my dilemma. Many good pointers but have not found mine so here goes: I have a 2006 2.4L do not know if it is a MK6 or not! It´s a Motorhome with only 47000kms. The ASM started suddenly acting up after a long drive when I was taking off from a stop it seemed to jump into gear with force and stalled. After shutting down opening the hood to check reservoir to see fluid level at OK, started engine and everything worked fine but only for a while. This is only a problem after a bit of a drive. All is fine for the first 30 mins or so. Took it to a Ford Garage, they ran diagnosis, changed the fluid in the ASM, bled the system but a Code is still reading:
TCM (Transmission Control Module) 1 problem exists, 1.P0805 Clutch Position Sensor Circuit Fault. They say that they can order only the whole unit but the price is crazy and they are not even sure that the fault will go away! Any ideas on what I could do before drastic measures?
Eagleman61
Re: Specific ASM Problem
Postby knobby1 » Wed Jul 16, 2025 12:46 am
Eagleman61 wrote:Hi there, I am new to this forum and have being searching here for answers to my dilemma. Many good pointers but have not found mine so here goes: I have a 2006 2.4L do not know if it is a MK6 or not! It´s a Motorhome with only 47000kms. The ASM started suddenly acting up after a long drive when I was taking off from a stop it seemed to jump into gear with force and stalled. After shutting down opening the hood to check reservoir to see fluid level at OK, started engine and everything worked fine but only for a while. This is only a problem after a bit of a drive. All is fine for the first 30 mins or so. Took it to a Ford Garage, they ran diagnosis, changed the fluid in the ASM, bled the system but a Code is still reading:
Firstly...welcome...
Must be last of the Mk6's as the Mk7 didn't come with an ASM box. Mk6 was discontinued on April 17th of 2006.
When working well, they're a good thing....but when they play up finding parts for the Mk6 ASM system is near impossible and finding people to work on them who know anything about them is also difficult. They haven't been produced since 2006...many people who own them and have issues give up and convert their ASM to a manual geabox instead.
There's are a few people on here who have them and do their best to keep them running. Only a small % of Mk6's were ASM though.
