This new to me mk6, first time to check the rear lights, nothing. Fronts work, right front indicator fast flashes the left makes the flasher box screech.
Does it have a Light Control Module? or a multi function module covering the rear lights?looked under the bonnet, under the passenger dash no luck.
Any suggestions? also I can not find a fuse/ relay location chart for the MK6, can any one help? thank you
I'll mention Ive put a mechanical fuel pump on it, though it should not matter?
