Dead cigar lighter sockets
Postby srj999 » Tue Aug 05, 2025 12:29 pm
I bought a 2018MY 2.0 Transit Custom Limited (UK spec) recently. The instrument panel has four power outlets, two USB-A sockets and 2 traditional 12V cigar lighter sockets. The USB sockets are, I'm guessing, 2 amp outlets, as they struggle to charge as fast as a satnav app drains my phone. I wanted instead to use the cigar lighters with a higher amperage adapter but neither cigar lighter works. The fuse (F13, 20A, according to the manual) tests fine, as did F14, another 20A fuse for the instrument panel auxilliary power unit (I swapped the two as a belt and braces trial).
I am assuming there is a break somewhere in the live feed, rather than failed cigar lighters. It would be bad luck indeed for both sockets to have failed. I have no idea how to get the sockets out and access under the instrument panel is extremely restricted. Any suggestions, people?
srj999
Re: Dead cigar lighter sockets
Postby MinorMatt » Wed Aug 06, 2025 11:15 am
srj999 wrote:It would be bad luck indeed for both sockets to have failed.
Sorry I can't help directly with your question - but don't discount this. If someone broke one, they are likely to have broken the 2nd in the same way!
Postby srj999 » Thu Jul 09, 2026 9:09 am
I wonder if the two 12V sockets are on different circuits to the two USB-A sockets, as I can charge a phone off both USB ports with no issue. If I can't sort the 12V units, I may simply rewire them (with in-line fuses) so they are permanently live.
srj999
Postby Altransit » Thu Jul 09, 2026 10:12 am
I would still test at least one of the sockets, they are a well known weak point :idea:
