Mk 7 Knocking Noise Under Cab - Matches Revs
Postby MattyFox » Wed Aug 06, 2025 5:02 pm
Hello all,
MK 7 TRANSIT 2.2 TDCI RWD 2013 - 120,000 miles
I'm getting some knocking noise coming from under the cab area it sounds like but I cant pin point it even from under the van. It is a dull knock and it matches the rpm of the van. It doesn't come straight from a cold start but normally once I get back home and park up I can hear it going.
Any advice on what it could be would be brilliant.
Here is a video with the knock - hopefully you can hear it okay:
https://drive.google.com/file/d/1Wqr2NG ... YbJCT/view
Thank you in advance :D
MattyFox
Re: Mk 7 Knocking Noise Under Cab - Matches Revs
Postby metalworker0 » Wed Aug 06, 2025 5:48 pm
sounds like a tyre
Postby knobby1 » Wed Aug 06, 2025 9:55 pm
MattyFox wrote:Hello all,
DMF starting to fail..?? Does the noise stop when the clutch pedal is pushed..??
Postby MattyFox » Thu Aug 07, 2025 10:09 am
metalworker0 - the van is stationary mate
knobby1 - thanks for the pointer. Although the noise is still there when clutch is pressed. Could it still be the issue then?
MattyFox
Postby metalworker0 » Thu Aug 07, 2025 5:35 pm
Answer number 2 then , common failure on most of these vans is crankshaft pulley damper assembly .. some have a lump of rubber in the middle that breaks up after a period of time ... check this out first.
rubber is stiff when cold and becomes more pliable when it warms up .. is how i came about this answer - plus the fact the video when played at full vol on my pc is not very loud .. and not very metallic sounding.
Postby MattyFox » Thu Aug 07, 2025 7:59 pm
I'll definitely get that checked out once I find it :D
Thank you so much Mark. Very much appreciate you taking the time to listen and write a reply. Legend!
MattyFox
Postby andz327 » Sun Aug 10, 2025 11:55 am
Like Laird knobberoo asked does the noise change when clutch pressed
andz327
Postby DanMK7uk » Mon Aug 11, 2025 12:34 pm
Apparently so. So MW shout of harmonic balancer / crank pulley worth a check OP
DanMK7uk
Postby andz327 » Mon Aug 11, 2025 1:22 pm
DanMK7uk wrote:Apparently so. So MW shout of harmonic balancer / crank pulley worth a check OP
Still awaiting an answer with regards to noise change when clutch pressed
andz327
Postby knobby1 » Mon Aug 11, 2025 8:17 pm
He did say the noise was still present when the "clutch is pressed"..!
Postby andz327 » Mon Aug 11, 2025 8:44 pm
Oops must have missed that one
andz327
