rear caliper bolts
rear caliper bolts
Postby roundtuit » Mon Aug 25, 2025 8:25 am
2014 mk7 2.2 fwd. the bolts holding my rear calipers have been completly rounded have an extraction set coming but will need new bolts anyone know the correct size bolts. not the carrier ones. i think they are a 15mm head
roundtuit
Re: rear caliper bolts
Postby metalworker0 » Mon Aug 25, 2025 3:03 pm
unclear from your wording what you are talking about .. which bolts then, if not the carrier ?
M12 x 35mm note that's 12mm thread diameter
these will not be any old bolts - they will be high tensile
look at the diagram .. are you talking HB1 on the diagram .. part number - 1386758
note: comes up as drive shaft bolt for ford ranger in ebay .. must be the same number
http://www.catcar.info/ford/?lang=en&l= ... EzMQ%3D%3D
if forum breaks link .. youll have to go through to it from here
well i can get to it from google .. but not from a link in the forum ... i don't know what anyone else is seeing
yes i have catcar.info back :) :) :) ....well... sort of .
Postby roundtuit » Mon Aug 25, 2025 7:48 pm
metalworker0 wrote:unclear from your wording what you are talking about .. which bolts then, if not the carrier ?
its the hb1 in diagram. apreciate the info. still trying to get the old ones out even with the extractor set having trouble getting them to budge
roundtuit
Postby metalworker0 » Mon Aug 25, 2025 8:47 pm
1. Someone may have put red loctite on them ... means they need to be heated up beyond 200c to melt the loctite.
2. Have you tried flank drive sockets - these are 6 point hexagon sockets that grip on the flats and not the corners like 12 point ones do.
How flank drive works... first picture is a mild version, as you see a spanner version is illustrated too ...the 2nd illustration here is a bit of an exaggeration to get the message across, but now bit late, as you've probably mullerd it beyond saving ..but get sockets like this and rounding off will become highly unlikely in the future. as these sockets grip on the flats and not of the peaks of the hexagons.
download/file.php?id=53020&mode=view
download/file.php?id=53019&mode=view
Postby andz327 » Mon Aug 25, 2025 9:43 pm
Slider bolts usually come with decent set of pads if thats what you need, rounded slider bolts are a new one to me , someone been using wrong size of socket
andz327
Postby metalworker0 » Mon Aug 25, 2025 10:52 pm
andz327 wrote:Slider bolts usually come with decent set of pads if thats what you need, rounded slider bolts are a new one to me , someone been using wrong size of socket
if im not mistaken - HB1 , that's what he said .. not slider but carrier bolts
Postby andz327 » Sat Aug 30, 2025 5:35 pm
ma bad.in first post he did say not the carrier bolts and thinks there 15mm......sorry metalman unfortunately i don't have time to read your copy and pasted multi paragraph answers..... least your back on catcar .... wonder who the somebody was that rounded the bolts in first place...
Doubt the extractor set will move them especially if nae heat
andz327
cron
