Help Please - Fault Codes PCM DTC P010F:23-24, PCM DTC P0299
Postby Johnnyt63 » Wed Aug 27, 2025 5:20 pm
Hi hopefully someone can help.
Ford Transit Mk8, 2014, 2.2TDCI, TREND, Front wheel Drive.
I have the following fault codes PCM DTC P010F:23-24, PCM DTC P0299 when i plugged into Forscan.
History
Lack of power took it to the a mechanic who replaced a cracked hose which i saw. I took it for a drive and warning lights came on. I took it back, smoke tested, no leaks, cleared all codes and put some forte turbo diesel cleaner in (as asked to by mechanic) and run it.
The fault codes only currently come up when I am in 4th Gear, 2800-3000rpm at approximately 68-72 mph when it goes into limp mode. Full information from scan can be seen below. Please if anyone could help it would be much appreciated
Full Forscan Info
===PCM DTC P010F:23-24===
Code: P010F - Mass or Volume Air Flow Sensor A/B Correlation
Additional Fault Symptom (:23):
- Signal Stuck Low
Status (-24):
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Freeze Frame #1:
-EVENT_TIME: 317945709 s (Tue Aug 26 13:58:22 2025) - Event time
-TOTAL_DISTANCE: 203304 km - Total Distance
-MODULE_VOLTAGE: 14.5 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 19 °C - Outside temperature
-PWR_MODE_KEY: Running - Power Mode Key State
-PWR_MODE_QF: Power Mode OK - Power Mode Quality Factor
-LOAD: 37.25 % - Calculated Load Value
-ECT: 91 °C - Engine coolant temperature
-MAP: 65.0 kPa - Manifold absolute pressure sensor
-RPM: 2753 1/min - Engine Revolutions Per Minute
-VSS: 102.0 km/h - Vehicle Speed
-IAT: 26 °C - Intake Air Temperature
-MAF: 31.97 g/s - Mass Air Flow
-TP: 94.51 % - Throttle Position
-RUNTM: 1163 s - Time Since Engine Start
-FRP: 132780.0 kPa - Fuel Rail Pressure
-EGR_PCT: 0.00 % - Commanded EGR
-BARO: 98.0 kPa - Barometric pressure
-CATEMP11: 567 °C - Catalyst Temperature Bank 1, Sensor 1
-CATEMP12: 434 °C - Catalyst Temperature Bank 1, Sensor 2
-APP_D: 43.92 % - Accelerator Pedal Position D
-APP_E: 43.92 % - Accelerator Pedal Position E
-TAC_PCT: 0.00 % - Commanded Throttle Actuator Control
===END PCM DTC P010F:23-24===
===PCM DTC P0299:00-24===
Code: P0299 - Turbocharger/Supercharger 'A' Underboost Condition
Status (-24):
Freeze Frame #1:
-EVENT_TIME: 316026287 s (Mon Aug 04 08:48:00 2025) - Event time
-TOTAL_DISTANCE: 203197 km - Total Distance
-OUTDOOR_TEMPERATURE: 16 °C - Outside temperature
-LOAD: 84.71 % - Calculated Load Value
-ECT: 93 °C - Engine coolant temperature
-MAP: 182.0 kPa - Manifold absolute pressure sensor
-RPM: 3160 1/min - Engine Revolutions Per Minute
-VSS: 117.0 km/h - Vehicle Speed
-MAF: 116.53 g/s - Mass Air Flow
-RUNTM: 1748 s - Time Since Engine Start
-FRP: 163420.0 kPa - Fuel Rail Pressure
-CATEMP11: 472 °C - Catalyst Temperature Bank 1, Sensor 1
-CATEMP12: 447 °C - Catalyst Temperature Bank 1, Sensor 2
-APP_D: 76.47 % - Accelerator Pedal Position D
-APP_E: 76.86 % - Accelerator Pedal Position E
===END PCM DTC P0299:00-24===
===OBDII DTC P0299-P===
Status (-50):
- Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II
===END OBDII DTC P0299-P===
===APIM DTC None===
Successful DTC reading, no error codes found
Module: Accessory Protocol Interface Module
===END APIM DTC None===
===SASM DTC None===
Module: Steering Angle Sensor Module
===END SASM DTC None===
===ABS DTC U0401:68-48===
Code: U0401 - Invalid Data Received From ECM/PCM 'A'
Additional Fault Symptom (:68):
- Event Information
Status (-48):
- Previously Set DTC - Not Present at Time of Request
- Test not complete
Module: Antilock braking system
Freeze Frame #1:
-EVENT_TIME: 317945671 s (Tue Aug 26 13:58:45 2025) - Event time
-TOTAL_DISTANCE: 203303 km - Total Distance
-MODULE_VOLTAGE: 14.8 V - Control Module Voltage
-POWER_MODE: Running - Power Mode Status
===END ABS DTC U0401:68-48===
===ABS DTC C0051:29-08===
Code: C0051 - Steering Wheel Position Sensor
Additional Fault Symptom (:29):
- Signal Invalid
Status (-08):
Freeze Frame #1:
-POWER_MODE: PM_Key_out - Power Mode Status
===END ABS DTC C0051:29-08===
Johnnyt63
Re: Help Please - Fault Codes PCM DTC P010F:23-24, PCM DTC P
Postby metalworker0 » Wed Aug 27, 2025 6:38 pm
you need to show actual EGR, plus actual wastegate percent at hard and medium acceleration so i can see whats going on, as they may be the trouble
plus have a look at the boost pipes
The 2.2 custom has a problem with the boost pipe rubbing on a bolt that causes a hole in it- where it passes behind the alternator. no one has confirmed this happens on the mk8
Postby Johnnyt63 » Wed Aug 27, 2025 7:02 pm
metalworker0 wrote:you need to show actual EGR, plus actual wastegate percent at hard and medium acceleration so i can see whats going on, as they may be the trouble
Thanks for your reply Mark, much appreciated.
I'll look into how i can retrieve this data with Forscan and hopefully get it up on here tomorrow. I will also have a look at the boost pipes.
Johnnyt63
Postby metalworker0 » Wed Aug 27, 2025 7:57 pm
keep get mixed up with these things, it will not be wastegate it will be turbo vane actuator percent, which would fail on actuator motor -- stripped gears, bad motor etc
