Any Tips?
Any Tips?
Postby longhair » Mon Sep 08, 2025 6:06 pm
I'm struggling to get the vaporiser off my custom. I have discovered it is blocked so I am trying to remove it, but it is refusing to undo. I have a decent 22mm open ended on it with a 18 inch bar slipped on it and all that is happening is the spanner is slipping round. I'm reluctant to use some heat on it being where it is close to the turbo and other stuff. The only way I can see of removing it is to cut off and use a socket on it, but I really wanted to try and save it and try to unblock it and use it again. Any suggestions or tips most welcome. Edit. Just found a tool made for the job, made by LASER tools so I might have to give that a go.
longhair
Re: Any Tips?
Postby metalworker0 » Mon Sep 08, 2025 7:36 pm
Along side that tool, i noticed they sell a thread chaser tool .. so presume you are going to have damaged threads after you get it out.
Re: Any Tips?
Postby longhair » Mon Sep 08, 2025 7:54 pm
I have various thread files already, so I'll hopefully be able to clean them up. Ordered the tool, should be here tomorrow.
longhair
Re: Any Tips?
Postby dumper » Mon Sep 08, 2025 9:51 pm
If you look at O’Reilly autos on YouTube he has to heat up most of them as for the use of thread files ok for the external threads on the vaporiser but you will need a internal thread chaser for the Dpf he has to use one on a lot of them
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Any Tips?
Postby longhair » Tue Sep 09, 2025 5:47 pm
Absolute f*** nightmare of a job. Even with the LASER tool, you still can't get any decent access to the vaporiser nut. Had enough of it today, going to have another go tomorrow, but looks like I'm going to have to cut the tube off and get a decent impact socket on it.
longhair
Re: Any Tips?
Postby metalworker0 » Tue Sep 09, 2025 7:38 pm
AS SAID
O'Riley .. will have a video showing the exact method he uses on this engine to remove it .
all the best.. mark
Re: Any Tips?
Postby longhair » Tue Sep 09, 2025 8:45 pm
I have seen most of his videos, the problem I have is the position of the nut that it has been tightened to, because the tool is only 6 sided, I am restricted in the position of the strongarm i can use in such a tight space, with very minimal movement.
longhair
Re: Any Tips?
Postby andz327 » Sat Sep 13, 2025 10:29 am
longhair wrote:I have seen most of his videos, the problem I have is the position of the nut that it has been tightened to, because the tool is only 6 sided, I am restricted in the position of the strongarm i can use in such a tight space, with very minimal movement.
What you don't see with mr O'REILLY'S vids is the amount of time it can take to remove these even with getting it red hot and if you can't get proper heat on it you'll struggle like fook, like you mentioned chop it and use impact socket and buy /use propane blow torch to get it glowing red
andz327
Re: Any Tips?
Postby longhair » Sat Sep 13, 2025 12:43 pm
Just got the bloody thing off. No wonder it was tight all the way. All you have is about an inch of movement to turn it. I had to keep getting it red hot, get a bit of a turn then get it red hot repeatedly. Absolutely sh*t design on Ford's part.
longhair
Re: Any Tips?
Postby metalworker0 » Sat Sep 13, 2025 1:16 pm
by the looks of things you'll need the thread chaser now
Re: Any Tips?
Postby longhair » Sat Sep 13, 2025 6:42 pm
Looks like I'll be getting a vaporiser. I won't be getting a genuine one at them prices. :shock:
longhair
Re: Any Tips?
Postby knobby1 » Sat Sep 13, 2025 9:20 pm
longhair wrote:Looks like I'll be getting a vaporiser. I won't be getting a genuine one at them prices. :shock:
Non-genuine ones are poor at best or just don't work well...we've found that out long ago.
Re: Any Tips?
Postby longhair » Sun Sep 14, 2025 1:04 pm
On second thoughts, I'm going to get a die and try to clean the threads up.
longhair
Re: Any Tips?
Postby metalworker0 » Sun Sep 14, 2025 3:00 pm
you'll probably need the die and the chaser
Re: Any Tips?
Postby longhair » Sun Sep 14, 2025 5:09 pm
Yeah, I'm getting both to be on the safe side.
longhair
