2014 Transit 125 t350 MK7 Coolant Leak
Postby Johnnyquk » Fri Sep 19, 2025 8:43 am
Hi Guys
Im hoping one of you could shed some light on a coolant leak i have it is pooring out on the rear of the engine drivers side top any idea what it could be ??
also i have a tapping coming from the camshaft area so im assuming possibly isues with th ladder?
any help or advice would be truly appreciated
Many thanks John
Johnnyquk
Re: 2014 Transit 125 t350 MK7 Coolant Leak
Postby knobby1 » Fri Sep 19, 2025 9:49 pm
Johnnyquk wrote:Hi Guys
Many thanks John
FWD or RWD..?? You don't say which you have..??
Hasn't popped a freeze plug has it..?? There's one on the head exhaust side.
Postby Johnnyquk » Tue Sep 23, 2025 12:32 pm
Sorry rear wheel drive
Johnnyquk
Postby metalworker0 » Tue Sep 23, 2025 4:11 pm
you can see the core plug, right in the centre of the picture here , also couple of hoses that could be the leak
https://i.ebayimg.com/images/g/1I0AAeSw ... l1600.webp
Postby knobby1 » Tue Sep 23, 2025 8:25 pm
metalworker0 wrote:you can see the core plug, right in the centre of the picture here , also couple of hoses that could be the leak
Perfect pic of the core plug in the head..! Could also be the EGR cooler leaking...not unheard of.
Postby Johnnyquk » Wed Sep 24, 2025 8:16 am
Thanks mark going to attempt to have a look this weekend
I also have a tapping noise coming from the the cam area is it likley to be the cam or the cam ladder its only done 80k and been serviced Regularly
Thanks for all your help :)
Johnnyquk
Postby metalworker0 » Wed Sep 24, 2025 5:55 pm
A video of the sound would/ may help people here diagnose the tapping.
Put it on youtube
Taking the auxiliary belt off and running for a few seconds ... would tell you if any of the ancillaries .. is causing the tapping .
