Mk6 Cranks, pumps diesel, no ignition
Postby mtnz » Tue Sep 30, 2025 6:13 pm
2002 MK6 Cranks, Pumps diesel to injectors, doesn't ignite.
No error codes.
Fuel injector pump recently replaced, lines bled.
Auto sparky inspected PCM no signs of any problems.
Ford have reprogrammed PATS to ensure clean Comms between PCM and injector pump module.
PCM details uploaded
Any hints?
https://www.carjam.co.nz/car/?plate=kyc236
mtnz
Re: Mk6 Cranks, pumps diesel, no ignition
Postby metalworker0 » Tue Sep 30, 2025 7:33 pm
2002 - 23 years old, what's the mileage, if its high do a compression test.
check also the valve timing .. as there could be something wrong with the chain
Postby mtnz » Mon Oct 06, 2025 2:06 pm
Ok thanks any idea on how we can check the valve timing... Around 300k
mtnz
Postby metalworker0 » Mon Oct 06, 2025 2:39 pm
need engine size ..
and if fwd or rwd
and at 300k you probably need a timing chain change
and you do need to do the compression test to rule that out
and i dont know what that link is in your first post .. security check ? looks too dodgy to me .. i dont give my email away
Postby mtnz » Mon Oct 06, 2025 7:13 pm
Ok thanks I'll do a compression test. The link isn't dodgy it contains all the details on the van. It's a New Zealand link so you've probably not seen it before. Shouldn't have been any request for an email from the site, but possibly it happened since you are probably not in NZ.
Anyway thanks Mate such a long drama stretching over several years now.
mtnz
Postby metalworker0 » Mon Oct 06, 2025 8:53 pm
ok 2.5 litre , auto 3 speed transmission , says two axles ... does that mean 4 wheel drive?
also a slow starter motor can stop these things firing up
and when you said 300k i thought miles... so not so high
Postby mtnz » Mon Oct 06, 2025 9:29 pm
Brand new starter motor now, still no attempt to fire, its actually a 5 speed with ASM.
Bloody annoying as I know the engine ran great prior to switching out the fuel injector pump and that there's no error codes, that it pumps diesel fine. The PCM has been reprogrammed with the fuel module by Ford.
It seems so close to firing but nothing anyone does works
mtnz
Postby knobby1 » Mon Oct 06, 2025 10:14 pm
metalworker0 wrote:ok 2.5 litre , auto 3 speed transmission , says two axles ... does that mean 4 wheel drive?
No such animal as a Mk6 2.5 litre 3 speed auto.
Postby metalworker0 » Mon Oct 06, 2025 10:30 pm
that's what it said in his link , also said 63KW! which is 85 hp ... is that correct
Postby mtnz » Mon Oct 06, 2025 10:38 pm
Yes it is incorrect in the official link Lord Knobrrot, it's a five speed with ASM.
mtnz
Postby knobby1 » Tue Oct 07, 2025 3:30 am
mtnz wrote:Yes it is incorrect in the official link Lord Knobrrot, it's a five speed with ASM.
It's not a 2.5 either...nor is it 85hp. The Mk6/Mk7 2.4 engine was never released as an 85ps.
The Mk6 ASM gearbox machines were all 2.4 90ps with what is essentially a normal MT75 5 speed box with auto clutch and auto shift mechanism bolted to it....and they were never fitted with a 3speed automatic gearbox.
I don't know where these "CarJam" places get their info from.
Postby mtnz » Tue Oct 07, 2025 4:12 am
Back of a Weetbix packet most likely. Probably only the VIN/ Chassis is correct. Right now Im on the verge of having to sell this perfectly fine van as a dolls house because everything works but nothing actually goes and noone knows here in NZ actually knows much about them it seems, especially Ford. Buy it for 30k, Spend 8k on it, sell it for about 10k even though I have no idea whats actually wrong with it.
Hard to believe that they designed a van to pump diesel but not actually go. You'd think they would have prevented it pumping if there was an issue and if it was pumping fuel it would fire.
I'd love to get rid of this god forsaken engine altogether and put something simple and reliable in it instead of this mass of spaghetti cabling and overly complicated fuel pump.
Just keep the ASM and flog it because the ASM has never missed a beat despite everyone telling me it would fail, it never did. How easy is it to take out the ASM without damage?
mtnz
Postby knobby1 » Tue Oct 07, 2025 6:23 am
mtnz wrote:Back of a Weetbix packet most likely. Probably only the VIN/ Chassis is correct. Right now Im on the verge of having to sell this perfectly fine van as a dolls house because everything works but nothing actually goes and noone knows here in NZ actually knows much about them it seems, especially Ford. Buy it for 30k, Spend 8k on it, sell it for about 10k even though I have no idea whats actually wrong with it.
Fuel injector pressure has to be pretty high and timed correctly for it to actually run, these engines run up to ~1600bar, (23200psi) fuel pressure. If there is any air in the high pressure side of the system, it will never run.
What code reader are you using..?? Mk6 is "NOT" OBD-II compliant so most of the newer readers won't work. You need Forscan.
Postby mtnz » Tue Oct 07, 2025 9:36 pm
Ford have used whatever their system is, and Ive used Forscan, others have used whatever theyve used. No error codes.
mtnz
Postby knobby1 » Wed Oct 08, 2025 6:19 am
mtnz wrote:Ford have used whatever their system is, and Ive used Forscan, others have used whatever theyve used. No error codes.
If you're getting no codes with Forscan, it must just be air in the system. They can be a pig to bleed.
