Rear step transit New 2025
Postby Nickr77 » Fri Oct 03, 2025 9:36 pm
Hi Everyone
Looking for a rear step for my brand new L3 H3 transit no towbar fitted has factory fitted rear sensors any suggestions
Nickr77
Re: Rear step transit New 2025
Postby dumper » Sat Oct 04, 2025 12:58 pm
Sorry nick haven’t got an answer but I’ve seen steps on older vans that they have moved the sensor from the bumper to the step don’t know if the wires had to be extended.
Wondering if you can help with my 75 plate problem with the AC off and the cab fan off as soon as I start it up the electric engine cooling fan starts up it does switch off sometimes but if I drive as little as 3 miles it’s on , the temperature gauge is not moving to more then half the outside temperature is only 12 degrees to me it’s got a fault but before I go into Ford I’d like to know that it’s not normal and it’s only mine doing it even if I was using the AC I’d only expect the fan to cut in and out and not run constantly.
Cheers John
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Users browsing this forum: The-Duke
