Baffling issues
Baffling issues
Postby Lukester147@ » Tue Oct 14, 2025 10:49 pm
Mk7 2014 transit custom. Engine service now light comes on intermittently . Seem to coincide with ABS light. Sometimes engine management light too. Loss of power. But goes away. Stopped van today and engine was making a strange humming noise for good 5 minutes with key out of ignition. Had it on computer and body control module was 1 error. Any suggestions? TIA, I took video of the humming noise.
Lukester147@
Re: Baffling issues
Postby metalworker0 » Wed Oct 15, 2025 2:25 pm
where is the video link?
Re: Baffling issues
Postby Lukester147@ » Thu Oct 16, 2025 2:19 am
Sorry forgot to add link.
Here it is https://share.icloud.com/photos/0c0Cknb ... 5x4IemCPOg
Lukester147@
Re: Baffling issues
Postby knobby1 » Thu Oct 16, 2025 5:17 am
Lukester147@ wrote:Mk7 2014 transit custom. Engine service now light comes on intermittently . Seem to coincide with ABS light. Sometimes engine management light too. Loss of power. But goes away. Stopped van today and engine was making a strange humming noise for good 5 minutes with key out of ignition. Had it on computer and body control module was 1 error. Any suggestions? TIA, I took video of the humming noise.
What was the actual BCM fault code..??
Re: Baffling issues
Postby metalworker0 » Thu Oct 16, 2025 1:58 pm
Never heard that noise before .
1. Stop / Start - i don't know what is fitted to 2014 mk7
One thing that comes with stop/start system on the later ecoblues (mk8 and custom) is an electric pump that pumps coolant to the cabin heater when the engine is stopped. . if it were to malfunction, relay stuck etc, then the pump would carry on running.
Fault code P2600
2. Front Wheel Drive / FWD, ONLY. Your radiator cooling fan is supposed to be running, to cool the engine after its stopped ... which it will do for a couple of minutes after prolonged long journey or in hot summer weather. or slow traffic ... but its trying to do that... but its seized.
3. FWD ONLY - Same as above but fault with radiator fan control unit, which is mounted on or near the fan motor ... Test 2 and 3 - by un-plugging it.
4 . Something wrong with the cooling system .. getting too hot / overheated .. and you are hearing "heat soak" causing, sort of a "water hammer"
5. A stepper motor controlled device such as EGR or turbo actuator .. has a relay at fault.
