wet boot floor
wet boot floor
Postby G15FTC » Thu Nov 06, 2025 10:37 pm
2015 lwb tourneo custom 9 seater
has anyone else suffered with wet boot floor on the n/s?
since recent heavey rain ive noticed van appeared a bit damp. i removed plastic boot liner tray and carpet in wet in one place
i know its not leaking from rear heater unit, it appears to be to the side of that just behind rear left seat.
have also cut n lifted carpet up that side and thrown out the wet rotting hardboard/mdf floor
the actual metal floor is dry thou?
G15FTC
Re: wet boot floor
Postby Frag » Fri Nov 07, 2025 9:16 pm
Does your rear washer still work ?
And has it got aircon also in that rear corner heater unit ?
Frag
Ford Technician
Re: wet boot floor
Postby G15FTC » Sat Nov 08, 2025 12:23 pm
rear washer does squirt ( wiper unit non funstioning)
yeah have rear aircon ....
G15FTC
Re: wet boot floor
Postby Frag » Sat Nov 08, 2025 1:59 pm
Just wondered because I’ve seen rear washer pipe come apart and leak into headlining
And wondered if it could be aircon condensate from rear heater,say if drain was blocked ?
Frag
Ford Technician
Re: wet boot floor
Postby G15FTC » Sat Nov 08, 2025 9:25 pm
I will investigate that area too, and also gonna do a leak tesk from rear side window also..
G15FTC
