where to place axle stands ( need to do front brakes)
Postby G15FTC » Sat Nov 08, 2025 12:22 pm
2015 ford tourneo custom lwb fwd
i know where jacking points are but where can i safely place stands?
want the whole front end up,
its stressing me out as just want to crack on and do front brakes.
The rears last weekend were a doddle to do lol
thanks
stressed G
G15FTC
Re: Swap a 2.2 with a 2.4
Postby Airthies » Sat Nov 08, 2025 2:17 pm
Anywhere between the two wishbone bolts on the front subframe is fine.
I usually add a small bit of wood between the stand and the subframe since it's a flat surface.
Sent from my Pixel 8a using Tapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: where to place axle stands ( need to do front brakes)
Postby Airthies » Sat Nov 08, 2025 2:19 pm
For getting the front hub and disk off have a look at this video.
It's not exactly the same but similar enough to what your doing.
https://youtu.be/D41EsmIsOsQ?si=amRdlXnpEPVHyPca
V86+patch
V86.04
X-Prog
C81
Airthies
Postby metalworker0 » Sat Nov 08, 2025 2:26 pm
from the custom
BEMM
Postby dumper » Sat Nov 08, 2025 5:49 pm
Axle stands are ok but for working at home I prefer wooden blocks I have a cut up railway sleeper that I put underneath the engine crossmember each side of the trolley Jack
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
