Strange knocking
Strange knocking
Postby Johnnyquk » Tue Nov 11, 2025 2:55 pm
Hi Guys
Im hoping someone can shed a light on this noise https://www.youtube.com/shorts/blySVyjTIRk video on youtube.
So far i have changed the head cams cam carrier cam ladder, injectors, new timing chain, water pump it was making this noise before i started so i was hoping it would resolve it but its still clacking.
2014 Mk7 done 88000 miles
however drives really well no loss of power starts on the button im at a loss wht to do next any help would be gratfully recieved
Johnnyquk
Re: Strange knocking
Postby metalworker0 » Tue Nov 11, 2025 3:30 pm
Sounds like rocker valve clearance to me, hydraulic lifter trouble .. but you've already sorted that .
with new parts .. good .. if used parts ... well then anything can go wrong
the only other recurring fault with these is; injector washers can sometimes make a tapping nose from not sealing.. this will also be indicated with chuffing pressure out of the oil filler cap when removed.
all the best.mark ..
Postby Johnnyquk » Tue Nov 11, 2025 3:45 pm
metalworker0 wrote:Sounds like rocker valve clearance to me, hydraulic lifter trouble .. but you've already sorted that .
thanks mark its had all new injector washers..This model doesnt have hydraulic lifters its mechanical rollers that sit on top of the cams via a cam ladder unless im mistaken
Johnnyquk
Postby metalworker0 » Tue Nov 11, 2025 4:28 pm
The lifters are tiny and you cant really see them in place .. so ive heard . unfortunately despite looking many times for illustrations of them in place .. i draw a blank .. also no videos showing them being replaced .. despite rockers arms and lifters being sold as separate items.
they must be there .. as if not, you'd be shimming the valves to take the clearance up like in the old 1.8 connects.
ford don't sell them on there own, only as complete assembly ... that you've just replaced, (well i think you've replaced them .. did you replace the part with all the rockers hanging off it ? ) this engine in other vans cars made by Peugeot Citroen .. in which the seperate lifters (ford call them tappets) are available hence all the references to them on ebay being transit and Peugeot etc
Postby Altransit » Tue Nov 11, 2025 7:37 pm
I seem to recall that Loot had this problem with his 2014 2.2 Custom, and that turned out to be a faulty injector :?
Maybe worth looking at :idea:
Postby knobby1 » Tue Nov 11, 2025 7:47 pm
Johnnyquk wrote:This model doesnt have hydraulic lifters its mechanical rollers that sit on top of the cams via a cam ladder unless im mistaken
Ummm....yes they do. You have 16 of them.
They live in the rocker ladder and also act as the pivot points for the rockers.
Postby mistyv6 » Wed Nov 12, 2025 5:25 am
mine made same noise caused by previous owner not changing oil and clogging up lifters
mistyv6
Postby metalworker0 » Wed Nov 12, 2025 6:09 pm
lifters - from defender 2.2 manual
Postby knobby1 » Wed Nov 12, 2025 7:36 pm
Does the noise go away if you put your foot on the clutch..??
Popssible DMF failing maybe..?? How many miles on the beast..??
Postby Johnnyquk » Thu Nov 13, 2025 9:37 am
No the clacking is constant only time it goes is when you turn the radio up :lol:
Johnnyquk
Postby knobby1 » Thu Nov 13, 2025 9:42 am
Johnnyquk wrote:No the clacking is constant only time it goes is when you turn the radio up :lol:
Might pay to pop the roker cover off and check for damaged loose rockers etc.
Postby metalworker0 » Thu Nov 13, 2025 4:35 pm
You said "head cams and cam carrier ladder" changed
that means not the rocker carrier ladder (item marked No2 and frame in first diagram )- if so then that's the answer -- change it -note: its a unit that comes with the rockers and lifters
struggling to understand what you've changed
Postby Johnnyquk » Fri Nov 14, 2025 9:47 am
Hi Mark
Yeh ive changed that as well from the block up i have changed it all it was clacking before im begining to think it may be the small ends
Johnnyquk
Postby metalworker0 » Fri Nov 14, 2025 2:33 pm
if its the small ends it will be due to oil squirters getting blocked and long oil change intervals.
impossible to steer you to a youtube video with noises on, as everyone has their own idea what a knock is
but at 88,000 miles ... non of your problems should be happening.
