Central locking issue
Postby ChrisownsaTransit » Thu Dec 04, 2025 1:56 pm
Hi all
I brought a 2012 transit back in May this year
Im currently converting it into a camper
Recently its developed an issue with the central locking
The drivers door is unlocked but none of the other doors will unlock
Passenger and all rear doors are locked and won't open
Ive tried unlocking from the inside, the fob isn't working either
Ive changed the fuse
Has anyone got any ideas?
Many thanks
ChrisownsaTransit
Re: Central locking issue
Postby Altransit » Fri Dec 05, 2025 10:58 am
Is the van in regular use?
Maybe the aux battery is flat :idea: (if you have two batteries)
Postby knobby1 » Fri Dec 05, 2025 9:32 pm
What our Altransit said..!
If you have twin batteries, the fron one is probably munted.
Lord Knobrot (Smithy)
Postby bortaf » Mon Dec 08, 2025 7:19 pm
i can remove my front battery and the C/L still works, remote doesn't but the key C/L still does, is mine wired wierd ??
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby knobby1 » Mon Dec 08, 2025 7:40 pm
bortaf wrote:i can remove my front battery and the C/L still works, remote doesn't but the key C/L still does, is mine wired wierd ??
Strange....normally the Mk7 twin battery setup uses the front battery for everything other than starting. When the ignition is turned on, the batteries are then connected in parallel until the ignition is turned off, then all accessories run off the single front battery, this is why the front battery often fails first.
Postby bortaf » Thu Dec 11, 2025 6:36 pm
TBH mine has been messed with a WHOLE LOT :lol: being an ambo, the battery wiring all looks and acts as factory but the builders may have messed with the factory setup elsewhere, the BCM has quite a few extra wires solderd in, i've still not got to bottom of everything :oops:
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
