Alternator Light On - Goes off on restart
Postby in_transit_vanlife » Tue Dec 09, 2025 11:59 pm
Hi All
I have a 2008 Mk 7 Transit with 2.4 tdi engine. Alternator was replaced last year but has now on occasions when starting from overnight the alternator light stays on. Normally I only notice the light is still on after driving a few hundred meters down the road. I stop turn off and restart and normally the light will go out. Sometimes it might take a km or 2 of driving before a restart turns the light off. Thinking it has been on mornings where it is a bit fresh, maybe a bit damp overnight?? Never had this issue later in day or other times when starting up. Volt meter shows normal output when alternator light isnt on.
Any clues where to look for a wiring or connection issue. Wonder if the alternator clutch pulley not engaging till warm or do they not work like that?
in_transit_vanlife
Re: Alternator Light On - Goes off on restart
Postby metalworker0 » Wed Dec 10, 2025 12:25 am
1.Loose belt that plays up when damp and slips on pulleys,
2. Belt in poor condition,
3 Corrosion inside back of alternator on the electronics, that holds moisture .. until its warmed up and dries.
4. Bearing on alternator, on its way, out causing belt to slip.
5. Could be all - battery terminals , earths , thick lives .. that are corroded where they bolt on .
if slippage of belt occurs caused by 1,2 and 4, it will usually be heard as a squealing / shrieking noise
Postby in_transit_vanlife » Wed Dec 10, 2025 2:20 am
Thanks Mark
Belt in good condition, tensioner & pulley replaced last year, no noises at all, doesnt appear loose so thinking will look at 3 & 5. Will get underneath and check wiring and terminals where I can.
in_transit_vanlife
Postby MinorMatt » Wed Dec 10, 2025 4:45 pm
I would have a look at the clutch in the alternator pulley - they normally either work or don't - but you could end up with a condition where it doens't grab unless its warm?
Postby andz327 » Thu Dec 11, 2025 1:55 am
The alternator voltage regulator is basically open to the elements on the back of it , and cleaning the contacts/brushes can sometimes help or replace if worn out, easy jobImage
andz327
Postby in_transit_vanlife » Sun Dec 14, 2025 12:59 pm
Thanks all will investigate further.
in_transit_vanlife
