1994 ford herald Aragon motorhome - fuel pump
Postby emsih » Mon Dec 22, 2025 12:15 pm
It is apparent that the fuel pump on our Herald has ‘gone’, and we are having difficulty sourcing a replacement. Any pointer or advice as to what we can do next would be greatly appreciated :) :)
emsih
Re: 1994 ford herald Aragon motorhome - fuel pump
Postby MinorMatt » Mon Dec 22, 2025 2:18 pm
Define fuel pump?
The one pulling fuel to the injection pump, or the injection pump itself?
Given its a Herald Aragon I assume its a Turbo Diesel with the lucas EPIC pump - but is it a late mk4 or an early mk5?
Postby emsih » Wed Dec 24, 2025 12:30 pm
Thank you for your response. Have attached a photo of what’s come off her if that’s any good, not mechanically minded lol
emsih
Postby Chug » Wed Dec 24, 2025 4:44 pm
That's the fuel injection pump, a Lucas Epic which are hard to find in good condition and trying to find someone to repair it is just as bad, and I think the DSA947 is the only one that isn't interchangeable with the other Epic versions, but Matt can advise on that.
If its not an auto gearbox van then it's possible to fit the more readily available Bosch VE Injection pump and throttle pedal.
Chug
Postby metalworker0 » Wed Dec 24, 2025 4:58 pm
epic means the injection pump
and 1994 the change over date for mk4 to mk5
so its here 2.5 diesel
mk4
http://www.catcar.info/ford/?lang=en&l= ... A9PUFJQjA1
or
mk5 2.5 diesel
Postby metalworker0 » Wed Dec 24, 2025 5:20 pm
Chug wrote:That's the fuel injection pump, a Lucas Epic which are hard to find in good condition and trying to find someone to repair it is just as bad, and I think the DSA947 is the only one that isn't interchangeable with the other Epic versions, but Matt can advise on that.
will leave the rest of the answers to you chug .. as i don#t know enough.
Postby Chug » Wed Dec 24, 2025 6:21 pm
No my knowledge on these is not so good, Matt is the best for Lucas Epic pumps, I've only ever really swapped them for the Bosch.
Chug
Postby emsih » Fri Dec 26, 2025 12:59 am
Hope you have both had a lovely Christmas Day. Thank you for your input so far, will hopefully have some info from Matt, :D there’s obviously no urgency right now, so will wait with fingers crossed. Thank you again :D
emsih
Postby Chug » Fri Dec 26, 2025 2:31 pm
Chug
Postby MinorMatt » Tue Jan 06, 2026 10:43 am
so as you have seen DSA 947 is for the mk4
You can swap to a bosch and get rid of all the engine management stuff.
Medway City Diesel are one of the few places that can rebuild the EPIC pumps
Postby bortaf » Tue Jan 06, 2026 12:45 pm
if your down south way try wade diesels in hoddesdon herts, they did one for me BUT it was like 15 years ago?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
