Full lock weird noise
Postby Harrypalmer » Wed Dec 31, 2025 10:36 am
Morning chaps
I’m getting a weird noise when steering is on full lock when I rev a little and the noise goes away on full lock.
Here’s what I’ve done so far. I’ve done so far. I’ve changed the steering pump checked all the pulleys cleaned all the belt and pulleys and everything seems to be okay however the noise persists has anybody got any ideas?
Cheers
Harry
Ford Transit 2019 eco Trend Panther diesel 2.0 mk7 V363 manual
Harrypalmer
Re: Full lock weird noise
Postby andz327 » Wed Dec 31, 2025 11:47 am
And your van is what ??? Model , year, engine size, FWD , RWD ,etc
Really you don't want to be holding steering on hard lock as it puts loads of strain on all steering components
Describe the noise?
andz327
Postby dumper » Wed Dec 31, 2025 5:26 pm
If you hold it on full lock it will make a noise because the rack is at its full moment and when you apply more revs it will open the pressure relief valve sounds to me all normal and you have spent money you didn’t need to .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Frag » Wed Dec 31, 2025 6:30 pm
Frag
Ford Technician
Postby andz327 » Wed Dec 31, 2025 7:28 pm
Or crank pulley on way oot
andz327
Postby Frag » Wed Dec 31, 2025 7:47 pm
I know he’s not posted his vehicle details
But another of his post said he has a 2019 2.0,
They have solid crank pulleys in the custom unless they are a MHEV (hybrid) :)
Frag
Ford Technician
Postby andz327 » Wed Dec 31, 2025 7:54 pm
frags the man.... a can't be doing that trolling to find van details mucker ma patience isn't what it used to be lol
aw the best for 2026 when it happens mucker
andz327
Postby Frag » Wed Dec 31, 2025 8:03 pm
And you.
Thanks :D
Frag
Ford Technician
Postby Harrypalmer » Thu Jan 01, 2026 12:06 pm
I mentioned before but I will add it to my signature in future
2019 2.0 Diesel eco trend panther
Thanks all for replies try to answer all questions
When I was underneath and belt off I checked all pulleys and none were seized , all span easily, no grinding or wobbling so I assume they are ok
Noise description: imagine when you are really cold and try to describe it to a little child….and you go brrrrrrrrr and rub your arms on your shoulders.
It’s like that brrrrr noise when your lips flap about. Sorry best I can do.
I agree maybe it’s normal and putting itt on full lock isn’t good.
Wasted money? Perhaps but learnt a lot
Thanks again all
Harrypalmer
Postby metalworker0 » Thu Jan 01, 2026 3:47 pm
is this on the move or manoeuvring.
not many here been inside a power steering rack to find out what wears out, as most people just replace it.
there are gasket and seal and bush overhaul kits for some (note we are not talking boots or track rods here) .. i know they are available for the mk5 mk6.. i know non are available for connect mk1, seen some once for mk6/7 Availability for m8 .. dont know
EXAMPLE OF MK5
https://www.ebay.co.uk/itm/274628422002?
example of mk6
https://www.ebay.co.uk/itm/196154083263?
if you could get a kit .. cheap to fix .. if not then whole rack costing a few hundred
Postby metalworker0 » Thu Jan 01, 2026 4:33 pm
i found these .. presumably they are the mount bushings .. wonder if they could cause a problem?
https://www.ebay.co.uk/itm/187419583545?
all the best... mark
Postby Harrypalmer » Fri Jan 02, 2026 1:14 pm
Cheers
I’ve looked underneath and I noticed the tensioner pulley. I checked it and it spins fine and smoothly
When I put the serpentine belt back on and got underneath to watch it all running whilst on idle I noticed that the tensioner pulley does judder back and forth about an inch or 2. When you look at it it’s a blur no should that be not juddering or is that normal as it keeps tension on the belt ?
Cheers
H
Harrypalmer
Postby Frag » Fri Jan 02, 2026 7:28 pm
https://youtube.com/shorts/H5wnkavnb58? ... 83q7PJx8JB
Videos nowt to do with me but shows the fault.
Alternator clutch pulley seized solid.
https://youtu.be/Oa14hQvZCoQ?si=EjAPE8kUDW-jZ6KK
Frag
Ford Technician
Postby Harrypalmer » Sat Jan 03, 2026 10:17 am
Cheers Frag
Videos great
My tensioner pulley moves like that judders.
I did check the alternator pulley and it seemed ok.
I can see I will have to make a video
Cheers for the help
H
Harrypalmer
Postby Frag » Sat Jan 03, 2026 3:33 pm
If you remove the headlight for access,
Then Either,
Disconnect belt from alternator pulley,and jam the fan blades through front of alternator.The pulley should turn freely by hand in one direction only,lock solid in other direction
Or
Leave belt on,with a screwdriver,you should be able to turn the fan blades through front of alternator.
Again,easily in one direction and not at all in other.
Frag
Ford Technician
