Injector restricted!
Postby Tomdye1 » Sat Jan 03, 2026 11:50 pm
Good evening!
My 2.4 120ps transit is playing up once again!
I had a small knock appear so sent all 4 injectors off for testing and 3 were a bit crap so replaced those 3 with recons.
I left the truck idling earlier whilst doing a recovery and once finished it had started to misfire.
I will attach an images of the codes below.
p02a8:00-2F - cylinder 4 restricted
p02a0:00-14 - cylinder 2 restricted
p0200:12-14 - injector circuit / open
I hadn’t had any issues like this before changing the injectors and now wish I had just left them alone!
If anyone has had similar issues they infinite knowledge would be great!
Tomdye1
Re: Injector restricted!
Postby knobby1 » Sun Jan 04, 2026 7:50 pm
Tomdye1 wrote:Good evening!
Assuming it's a Mk6 2.4..?? You don't actually say what model it is.
It can't have an "injector circuit / open" if it's a TDDi, they're mechanical injectors, not electronic.
What code reader did you use.??
Lord Knobrot (Smithy)
Postby Tomdye1 » Sun Jan 04, 2026 11:40 pm
Sorry I should have said Mk7 2.4!
Tomdye1
Postby Chug » Mon Jan 05, 2026 12:21 am
Did you code in the recon injectors? if so then I would have a thorough check of the wiring to the injectors, you may have disturbed something.
Chug
Postby knobby1 » Mon Jan 05, 2026 7:53 pm
Tomdye1 wrote:Sorry I should have said Mk7 2.4!
No such animal as a 2.4 120ps Mk7....which is why I mentioned Mk6.
Can only be a 100, 115 or 140 if it is a 2.4 Mk7.
Postby Tomdye1 » Mon Jan 05, 2026 11:52 pm
Sorry I should have actually read before I clicked post! It’s a 140
Tomdye1
Postby knobby1 » Tue Jan 06, 2026 12:14 am
That's a bit better....Did the recon injectors come with new correction factor codes..?? If so, were the injectors coded and learns done after the injectors were fitted..??
It will never run properly until the learns are completed "successfully". Perfomance and fuel economy will suffer and she'll be a bit "noisy" with diesel knock.
Postby Tomdye1 » Tue Jan 06, 2026 10:14 am
Sorry I should have actually read before I clicked post! It’s a 140[/quote]
Lord Knobrot[/quote]
All were recoded in to the correct cylinders but the injector pilot learn would not complete as the temperature was showing at 87 degrees and wouldn’t change, not sure if this could be caused by a faulty sensor
Tomdye1
Postby knobby1 » Tue Jan 06, 2026 8:03 pm
Tomdye1 wrote:All were recoded in to the correct cylinders but the injector pilot learn would not complete as the temperature was showing at 87 degrees and wouldn’t change, not sure if this could be caused by a faulty sensor
CHT sensor is in the rear of the cyl head, pig of a thing to get at. Not uncommon for them to fail.
Pretty sure you need to be in a certain range (CHT) for the learns process. I have the problem of keeping it cool enough.
Does the temp show low when the engine is cool/cold..?? And climb normally as the engine warms up..?? They normally sit ~90C-ish.
