Need help analysing this video telemetry of my 2.2 155ps
Postby 89transfers » Mon Jan 12, 2026 4:27 pm
I want to know if that is normal or it's caused due a bad tuning (DPF, SCR, EGR = OFF)
Specially EGR and MAF sensor fighting each other.
https://www.youtube.com/watch?v=WCbN380W848
89transfers
Re: Need help analysing this video telemetry of my 2.2 155ps
Postby metalworker0 » Mon Jan 12, 2026 4:47 pm
all your stuff is mainly temperatures .. i don't know what you are pointing out
if you wanted to know what the EGR was doing, you'd be putting: EGR percentage open - "desired" or "commanded" and "actual" pids up and not temperatures.
we are usually looking at loss of boost pressure , caused by:
.. boost pressure pipe leak
... EGR stuck open fault
.. and deepening what turbo you have: waste gate stuck open or actuator faulty
oh yeah .. minus 40 ones .. either faulty , unplugged or not used EG. only used in duel exhaust V8 set-up
so you must pick the pids that are relevant to the issue .
the video
we can not see what you are doing with the throttle .. if cruising or accelerating , we do not know that..
