Transit mk6 2.4 recovery truck immobiliser
Postby hodgy » Thu Feb 05, 2026 2:47 pm
Hi everyone is there anyway that you can bypass the immobiliser on a mk6 transit as of now it starts then cuts out it has been starting most then the odd day it wouldn't now it is starting but cutting straight out immobiliser light goes out as normal and in the past it has started even with the immobiliser light flashing fast any help would be gratefully appreciated thanks chris
hodgy
Re: Transit mk6 2.4 recovery truck immobiliser
Postby knobby1 » Thu Feb 05, 2026 9:41 pm
hodgy wrote:Hi everyone is there anyway that you can bypass the immobiliser on a mk6 transit as of now it starts then cuts out it has been starting most then the odd day it wouldn't now it is starting but cutting straight out immobiliser light goes out as normal and in the past it has started even with the immobiliser light flashing fast any help would be gratefully appreciated thanks chris
What fault codes are you getting..?? Guessing is pointless.
Crank sensor may not be happy....Mk6 TDDi will crank, start and stop if the sensor is not happy.
Is the glow plug light flashing..??
Lord Knobrot (Smithy)
