Watch - drive shaft centre bearing clamp fwd Transits
Postby metalworker0 » Fri Feb 06, 2026 6:22 pm
Good Info. about the One Use Clamp, this info probably many of you guys plus me didn't know about!
https://www.youtube.com/watch?v=lXnGESscDiU
i didn't even realise this was a problem
i will be ordering one of these clamps, to Keep in stock, they are quite cheap even for genuine ford £5 or £6.. should i have to do a clutch or change a drive shaft .. as too late then when you are right on top of the job or remember it even
applies to all front wheel drive transits as far as i know
Re: Watch - drive shaft centre bearing clamp fwd Transits
Postby Airthies » Fri Feb 06, 2026 9:21 pm
My suspicion is that the shaft was not fully home when the clamp was installed, more than likely with some form of impact wrench or ratchet and caused the clamp to stretch and deform then once driving and being loose it's rattled it's merry heart out till it's walked off the job.
I'd reckon there's countless FWD fords out there running original brackets that will perform and never fail as the video shows.
Not that it's not good practice to change these and for the cost that you state for them.
I don't think I'd start a panic over it, if there's a shaft been changed and it's not giving any issues.
It's just Another reason a RWD is better
Sent from my Pixel 8a using Tapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Altransit » Fri Feb 06, 2026 11:05 pm
Airthies wrote:I'd reckon there's countless FWD fords out there running original brackets that will perform and never fail as the video shows.
I have, and have had, many FWD Fords, a few of which have done well over 200k miles, and are still going, and I can truthfully say that I've never had this problem, or any other problem with the transmissions or driveshafts.
I have, however, had the odd problem with propshafts, and diffs, on the RWD's :lol:
Airthies wrote:It's just Another reason a RWD is better
Don't open up that particular can of worms again :roll: :P :lol:
Postby Airthies » Fri Feb 06, 2026 11:57 pm
Oh the blasphemy.... I've never had more than my fair share of prop bearings, UJs, diff gears all fail but never had an intermediate drive shaft support bearing fail on a RWD
Altransit wrote:Don't open up that particular can of worms again :roll:
Can of worms? CAN OF WORMS!!!!
it's only a debate when others don't see the true path to pure enjoyment
V86+patch
V86.04
X-Prog
C81
Airthies
Postby bortaf » Sat Feb 07, 2026 8:45 pm
Never changed one and never had a comeback, well i did but that was TPUK DMF deleit kit that was wronge but ,,, i digress, to be frank most YT vids are either click bait, BS, or overplayed to get views or they pose fake questions to themselves just to answer them, read the posts below the vid and you'll a few on there pretty much think it BS, obv the Sycophants on there have their tongues firmly up the video makers arse (sorry ASS) claiming him to be the 2nd coming or sumink but thats YT :lol:
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby andz327 » Sun Feb 08, 2026 5:25 pm
never had a problem and ive done well over a million miles in fwd transits, nobody i know has had the problem , I've never even heard of garages replacing these including mates gearbox shops .... someone hasn't tightened it up properly is more like the problem. . ..sorry but not even watching the video
andz327
