Burnt clutch
Burnt clutch
Postby Gray Glover » Mon Feb 09, 2026 9:03 pm
Hi all newbie here,
So my situation is that i got bogged down in my 2017 2.5 long wheel base transit, without a doubt i have burnt the clutch out but i am wondering if any other damage has been caused and which parts will need replacing- i literally have to stand and press on the clutch for any kind of action?
Gray Glover
Re: Burnt clutch
Postby dumper » Mon Feb 09, 2026 10:10 pm
You say you have burnt out the clutch what is it actually doing is it slipping or can you not get it in gear if a clutch is burnt out it wilt be slipping or no driver at all if you can’t get it in gear then it’s a problem with the hydraulic system could be as simple as air in the system.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Burnt clutch
Postby Gray Glover » Tue Feb 10, 2026 1:00 am
There is a constant ‘burnt’ smell and I have to virtually stand up on the clutch to engage any gear, the biting point is then virtually at the top. I have since noticed a fluid dripping when I start the van and engage a gear
Gray Glover
Re: Burnt clutch
Postby dumper » Tue Feb 10, 2026 9:58 am
Drop the box out and charge the complete clutch and dual mass flywheel by change the dual mass I don’t mean fit a solid one .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
