Transit mk6 fuel filter housing
Postby hodgy » Wed Feb 11, 2026 6:04 pm
Hi everyone I have a 2006 mk6 transit recovery truck 90 bhp which needs a new fuel filter housing.i am struggling to find one any ideas on where part number would be.the only ones I can find seems to be for mk7 transit with water sensor on could I use one of those and also any advice on fitting should I find one any help and advice appreciated thanks chris
hodgy
Re: Transit mk6 fuel filter housing
Postby DanMK7uk » Sun Feb 22, 2026 3:30 pm
hodgy wrote:Hi everyone I have a 2006 mk6 transit recovery truck 90 bhp which needs a new fuel filter housing.i am struggling to find one any ideas on where part number would be.the only ones I can find seems to be for mk7 transit with water sensor on could I use one of those and also any advice on fitting should I find one any help and advice appreciated thanks chris
There are like 3 different ones .. unfortunately cat car parts is playing up il try to find you the part number if someone don’t before.
https://tpuk.net/fuel-filter-housing-wi ... 1ZW6skNx1I
I believe this would fit the 2.4 90 ps but do your own research with the part number or give them a call to check compatibility
DanMK7uk
Postby knobby1 » Fri Mar 06, 2026 9:43 pm
There are a few different fuel filter assemblies for the Mk6 depending on year model and engine size/type.
https://www.catcar.info/ford/?lang=en&l ... NzkyKzA%3D
You can use a Mk7 filter assy if you like...the water in filter sensor is not really part of the filter housing...it's just a different drain plug on the filter itself....not used on the Mk6.
Lord Knobrot (Smithy)
