Foam gasket for sliding door actuator
Postby Xoq13 » Thu Jun 11, 2026 2:57 pm
Hi Everyone,
Recently purchased a 2020 Ford transit 250. The sliding door would not open from the inside. Apparently it was a problem with the actuator so I had to replace the whole unit. Part sk4z-61264a00-a. After getting everything installed, I noticed there was no foam gasket where the latch mechanism is on the back part of the door. Did a lot of searching, but cannot find this part anywhere. Does anyone know the part and where I could purchase it?
Thanks.
Jason
Xoq13
Re: Foam gasket for sliding door actuator
Postby metalworker0 » Thu Jun 11, 2026 3:37 pm
sorry not familiar with it .. and there are so many variegations on the door .. i will not be able to point you to the right one ... start here .. look for the part number .. then put it into ebay or google
http://www.catcar.info/ford/?lang=en&l= ... EwMw%3D%3D
if it turns out that it isn't available
all I can say is, make one yourself
closed-cell-foam sheet is available on ebay.. plain or adhesive backed
or i can give you an alternative idea
that is roofing rubber .. plenty of jobs going on through out every-bodies neighbourhoods .. where they will probably give you off cuts for free .
you can use it .. single thickness or double it up as required
ive just made gaskets for my boast out of the stuff .. very easy
Postby Xoq13 » Thu Jun 11, 2026 9:01 pm
Awesome, Thanks. That is helpful. Guess it wouldn't be too hard to make. Bummer that the $400+ actuator system didn't come with it.
Xoq13
Postby metalworker0 » Fri Jun 12, 2026 10:30 pm
oh forgot laminate flooring underlay is the same stuff
