dumper wrote:Not sure but it may be that your battery’s are ready for a change I know that they are disconnected when ignition is off but I’ve found over my working life that duel battery systems ether 12 volt or 24 volt if one battery is weak and you charge only one the old battery will kill the new one at work when told to just charge the weak one 9 out of 10 times it’s killed the new battery it’s been always nice to say to so called management told you so
Kimbyyri wrote:Custom battery.
Altransit wrote:Random alarms are often related to dropping battery voltage.
When unlocking, you need to open and close the drivers door, otherwise the van will lock itself after a couple of minutes.
Which battery are you charging with the solar?
