Transit mk7 2.2 euro 4 strange resonance
Postby Jm7812 » Wed Jul 22, 2026 9:27 am
Hi folks,
My vans started making a strange noise, it sounds like a droning at 1500rpm then disappears and reappears at just under 3000rpm sounding like air blowing over a bottle. Noise disappears sharply at 3000 rpm.
Had a new turbo which made no difference
Smoke pressure tested intake and found no leaks.
Has a hole in exhaust flexi but it’s been like it for years and only just started making the noise
Doesn’t make the noise at idle but does have some slight blowing/grrr sound at those specific rpm
Any ideas?
https://youtube.com/shorts/bfpjRISj0nM? ... 4TlkHJNky1
Jm7812
Re: Transit mk7 2.2 euro 4 strange resonance
Postby metalworker0 » Thu Jul 23, 2026 5:55 pm
video hopeless you don't hold it there for long enough ..
so i guess no one can answer with so little input
Postby Jm7812 » Thu Jul 23, 2026 9:13 pm
Thanks for having a listen.
Longer video it’s making the noise throughout however loudest as I approach 3k rpm
https://youtube.com/shorts/qnspm4ZekfQ? ... h7V4SwUWlY
Jm7812
Postby Jm7812 » Thu Jul 23, 2026 9:14 pm
metalworker0 wrote:video hopeless you don't hold it there for long enough ..
Thanks for listening it’s hard to keep it making the sound as slight throttle position change makes it go https://youtube.com/shorts/qnspm4ZekfQ? ... h7V4SwUWlY
Jm7812
Postby metalworker0 » Thu Jul 23, 2026 9:38 pm
That's a hard one, that could be lots of things!
for me it means typing a huge list of things to check, when i know that someone here has had that happen and will point you to exactly what it is ..
If no one comes here by this time tomorrow and tells you what it is
Then i'll make the list out of what to check and how to check..
btw .. the most simple thing it can be, is a loose heat shield
all the best..mark
Postby Jm7812 » Fri Jul 24, 2026 1:12 pm
metalworker0 wrote:That's a hard one, that could be lots of things!
all the best..mark
Sounds promising, thanks. Just about had enough of it now!
Jm7812
Postby Jm7812 » Fri Jul 24, 2026 6:43 pm
Some extra info - the noise can only be heard inside the cab! Sounds normal from outside
Jm7812
Postby metalworker0 » Fri Jul 24, 2026 6:58 pm
That statements only made it worse for me to diagnose
NOW i got to ask is it the speed its hitting or the RPM
Yes i know you show .. so much rpm and the sound happens .. but that could also equate to a certain speed, cause if so we'll be looking at air vents . windows, gear linkages, driveshaft , engine mounts , engine vibration damper=the crank pulley.
i say ..
one thing at a time
You have a look at the heat shields .. and report back
this could go on for a long time .. unless someone comes here .. having heard the same thing and knows its cure
all the best mark
Postby Jm7812 » Fri Jul 24, 2026 8:37 pm
metalworker0 wrote:That statements only made it worse for me to diagnose
i say ..
one thing at a time
all the best mark
RPM related not speed.
It’s not heat shield, I put some self tappers in to tighten it and there was no difference sadly
Thanks again for trying to help
Jm7812
