cutting out
cutting out
Postby rob4155 » Sat Aug 01, 2026 11:36 am
HI,I have a 2010 fwd ford transit 2198cc transit 85 t260m,which randomly cuts out then 3-5 seconds carry,s on running as i said its not every day just random but after 3-5 sec carry,s on running as though nothing has happened,has anybody any ideas what is causing this to happen,thanks
rob4155
Re: cutting out
Postby metalworker0 » Sat Aug 01, 2026 3:09 pm
You'll have to plug it into a diagnostic scanner , preferably forscan
The only thing i can think of for now is the clutch paddle switch .. which is there to detect when the clutch is pressed in and give it a few extra revs to carry it through, its an anti-stall feature .. these do fail.
Re: cutting out
Postby rob4155 » Sat Aug 01, 2026 3:54 pm
hi,thanks for that, i do have forscan so will scan and let you know
rob4155
Re: cutting out
Postby metalworker0 » Sat Aug 01, 2026 4:14 pm
oh btw .. i meant pedal
Re: cutting out
Postby rob4155 » Sat Aug 01, 2026 8:27 pm
will scan it sunday and let you know
rob4155
Re: cutting out
Postby knobby1 » Sat Aug 01, 2026 9:26 pm
rob4155 wrote:will scan it sunday and let you know
When was the fuel filter last replaced..?? When were the learns last done..??
Lord Knobrot (Smithy)
Re: cutting out
Postby andz327 » Sat Aug 01, 2026 11:02 pm
cuts out and you need to restart ? or power just dies then comes back a few seconds later ??
andz327
Re: cutting out
Postby andz327 » Sat Aug 01, 2026 11:04 pm
metalworker0 wrote:oh btw .. i meant pedal
clutch pedal that cuts engine out??
andz327
Re: cutting out
Postby metalworker0 » Sat Aug 01, 2026 11:25 pm
anti stall switch
a stall is an engine cut out is it not
some people don't give all the info , just making sure, they call a stall a cut out.. etc
we go around in circles sometimes
Re: cutting out
Postby rob4155 » Mon Aug 03, 2026 11:10 am
power just dies then comes back on,scanned with forscan only error code was P0480 fan 1 control circuit,circuit short to ground or open,fuel filter was changed last year
rob4155
Re: cutting out
Postby knobby1 » Mon Aug 03, 2026 7:59 pm
rob4155 wrote:power just dies then comes back on,scanned with forscan only error code was P0480 fan 1 control circuit,circuit short to ground or open,fuel filter was changed last year
Again...When were the learns last done..??
Re: cutting out
Postby metalworker0 » Mon Aug 03, 2026 9:32 pm
if knobbys advice doesn't work .
Then watch this video from 6 mins
i don't have enough knowledge on the pumps .. but this guy does
You have to tweak the subtitles on with the gear symbol
https://www.youtube.com/watch?v=hXoVlJ4ects
Pay attention on what he is saying about buying cheap
Wish he did english one ..
Re: cutting out
Postby rob4155 » Wed Aug 05, 2026 4:52 pm
learns ??
rob4155
Re: cutting out
Postby gotgcoalman » Wed Aug 05, 2026 5:26 pm
metalworker0 wrote:if knobbys advice doesn't work .
Is that the bloke off the crystal maze?
Sent from my LE2101 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Re: cutting out
Postby metalworker0 » Wed Aug 05, 2026 5:34 pm
Learns:
It means you plug it into diagnostic laptop etc .. and using .. for instance forscan, you press a button that sets it up again, compensates for wear and drifted settings .. so that it adjusts the software so it runs correctly. sort like a retune .
You cant do this with a cheapo scanner ..that only gives you the codes .
forscan is free and downloads to a laptop
You have to be sort of computer savvy to use it
To learn what's involved, type in forscan on youtube
