Mk6/7 REAR SUBFRAME
Mk6/7 REAR SUBFRAME
Postby misterdog » Fri Aug 07, 2026 2:42 pm
Rear subframe on my Mk6 failed it's MOT, Ford say part no longer available, will a Mk7 part fit? or does anyone know someone who can fabricate something nr Sheffield.
I'ts a LWB RWD.
Ta.
2002 Mk6 90 T350 2.4TDDI
misterdog
Re: Mk6/7 REAR SUBFRAME
Postby metalworker0 » Fri Aug 07, 2026 5:49 pm
it's only a subframe if you are able to unbolt it .. which is not so .. so it;s the rear frame or chassis .. which would have to be patched .. or sections welded in ..
This would be economical to do yourself .. but if you had to pay someone to do it properly .. may work out costly and perhaps more than the vehicle is worth, unless its a camper or ice cream van .. than its different.
Postby knobby1 » Fri Aug 07, 2026 10:01 pm
misterdog wrote:Rear subframe on my Mk6 failed it's MOT, Ford say part no longer available, will a Mk7 part fit? or does anyone know someone who can fabricate something nr Sheffield.
I'ts a LWB RWD.
Ta.
They don't have a rear subframe as such...just cross members and weldable plates etc...
https://www.catcar.info/ford/?lang=en&l ... ArMA%3D%3D
Even the "youngest Mk6" is 20 years old now...so finding new factory body parts for them will be near impossible, there are companies who make some repair parts but not everything is available they are few and far between. Most people just make up and weld replacement panels themselves.
Getting someone to make the parts and weld it professionally will probably cost more than the van is worth.
Lord Knobrot (Smithy)
Postby misterdog » Sat Aug 08, 2026 3:19 am
Oops I meant the Rear Crossmember, the subframe got an honorary mention as an advisory.
Ford have a crossmember available but for the Mk7, it looks identical to mine apart from 2 extra captive nuts welded on.
I wondered if anyone has a Mk7 could they measure the length of this to see if it will fit my Mk6..Mine measures 1425mm.
Thanks.
misterdog
Postby metalworker0 » Sun Aug 09, 2026 2:30 pm
the only way to display the picture in your post is to open up in new tab
i searched forever and cant see that actual crossmember anywhere in ebay
you have to ID your crossmember on this drawing
as you can see there are several cross members marked as : 1 , 2 , 3, 15, 16 and 14 so six to choose from.
http://www.catcar.info/ford/?lang=en&l= ... NjAwKzA%3D
if ive picked out the right drawing
if not pick from list
http://www.catcar.info/ford/?lang=en&l= ... PT1BMDI%3D
only then i can come close to helping you out
Postby andz327 » Sun Aug 09, 2026 7:43 pm
metalworker0 wrote:the only way to display the picture in your post is to open up in new tab
his pictures ok
andz327
Postby misterdog » Mon Aug 10, 2026 11:28 pm
The Ebay listing is ' Genuine Ford Rear Floor Cross X Member 1386729' which is for the Mk7 looks identical to mine, though the Ford parts Ebay guy says that mine is part 1213694. I asked if he could measure it but no was the answer. Given the cost it is too much of a risk.
So I'm going to fabricate my own section for it, but many thanks for trying to help.
misterdog
Postby metalworker0 » Tue Aug 11, 2026 12:07 am
number 9 on this diagram
http://catcar.info/ford/?lang=en&l=bWFy ... NTg0KzA%3D
not that i can help you anymore .. ive searched and found nothing
Postby andz327 » Sat Aug 15, 2026 12:59 am
metalworker0 wrote:number 9 on this diagram
would be easy enough to get in about it to make your own up if your a decent welder , or patch it but remember if patching it needs to be full continuous weld around the patch for to pass mot
andz327
