knobby1 wrote:Dirty Murphy wrote:Hi, I didn’t want to drop this in the ( excellent ) “AXLE INFO” thread .
In my pick up truck( 46 dodge ) the transit engine revs out in top around 56 MPH ,
I know there’s calculators on line to help work the numbers out …..knowing what I have to work with first .
Here’s the pic
"Looks" like a Dana axle, similar to the one I have in my Mk7 2008 model, the earlier Mk6 with the TDCi engine also had the Dana axles. For the ratio, can you not just do a propshaft vs wheel rotation calculation.?? Turn "both" rear wheels one rotation and count the propshaft rotations, this will give a fair idea of what ratio you have. Do you know what model Transit the axle came from..?? We may be able to tell from that, there are only a set amount of different ratios for a given model.
High rpm at 56mph (or a tad over 90kmh) would suggest a high 4.XX or even a 5.xx ratio....depending on wheel size of course.
Lord Knobrot (Smithy)
Easier jacking one wheel and doing 2 wheel rotations and count prop rotation to get reading than trying to match spinning both wheels.
It's not Mk7, possibly Mk5 but pics of wheels &stud numbers and PCD would help though being in a pickup it may have totally different axle tubes and hubs welded to a common diff case.
More pics of the diff casing would also help
Image search may bring up more info.
But the diff cover does not match any common types.
10 bolt covers are quite common, the basic housing outer shape is similar to some Dana cases but the profile does not look like any on the charts I usually referenced from.
Ps Mk7 is not a actually Dana
Sent from my Pixel 8a using Tapatalk
2008 350LWB 115PS ex fitters van "retired"
Bikes, yes, a few bikes.
V86+patchV86.04X-ProgC81
