by metalworker0 » Tue Sep 29, 2026 1:07 am
My suggestion on taking the engine out is because to replace all core plugs including number 15 at the back of engine.. basically getting everything out of the way to get the tappet cover removed ,, getting all the layers off the front( several alloy castings one over the other) ..... could leave you with just the bare block and head in the van and still struggling. - i don't know .
Worst case scenario and to do with age 35 years old.
I can tell you now , that once the core plugs are removed, its been my experience, (this is working on 10 - 15 year old engines, newer engines at the time than yours) ,you will see a couple of inches of rusty crud or even casting sand in the bottom of the water jackets.
Watch those Pakistan casting videos, or the bell foundry videos, see how hard that sand is to get out, lots of chiselling.. and you'll know why manufacturers don't do a good job of this when nobody is looking at them.
So, its handy to have the engine out be able to roll it over and blast with pressure washer and not get the water into the sump.
You can do all of this work with the engine still in .. if you want to .if you only think you are owning it for a couple of years .. then yes.
All plugs --- yes .. because, its likely, all will be in a similar rusty state ... or cross fingers and just do the bare minimum, its up to you .. good time to have a look at the clutch.
No, i don't know the order of procedure .. but many engines in vans come out through the bottom. or through the front .
