Transit Mk 6 flash 23, and error codes
Postby _Mcmoo_ » Sun Oct 11, 2026 10:25 am
Morning All,
I've got a 2001 transit 2.0L Duratorq DI with 45k on the clock. Just passed an mot with some minor work.
A couple of times recently she had been difficult to start, turning over but just not catching, a few weeks ago I went to go out and she just wouldn't.
Bit of tinkering, and I've got a code 23 on the immobiliser next to the clock.
This lead me down the route of removing the ecu on the fuel pump and sending it off to be repaired, done this, reconnected it, but its still the same.
I've just got a forScan reader (should have done this first) and got a list of error codes.
Is this a new fuel pump, and a reprogram or any suggestions on what I should be looking for or checking next?
Code dump from forScan:
===PCM DTC P0149===
Code: P0149 - Fuel timing error reported by FIP
Module: Powertrain Control Module
Diagnostic Trouble Code details
This DTC may be caused by :
Static pump timing incorrectly set after a pump replacement.
For additional information refer to:
TSB Number
8/2004
If DTC P1564 is present and the engine is knocking, renew the FIP timing solenoid.
TSB Number
64/2004
For further diagnostic information refer to the appropriate section of eTIS.
Air in the fuel system
Blocked kinked or crushed fuel lines
Outlet fuel connector pressure control valve seized or blocked.
Blocked external filter
CPS circuit fault
FIP supply voltage
CPS
===END PCM DTC P0149===
===PCM DTC P1664===
Code: P1664 - FIP malfunction
FIP malfunction
FIP timing chain tension
PCM
FIP
Carry out the CAN Test.
===END PCM DTC P1664===
===PCM DTC P1564===
Code: P1564 - FIP requesting reduced fuelling mode
The FIP has identified a fault that may cause damage to the engine
If any other DTCs are present address these first.
===END PCM DTC P1564===
===PCM DTC P1608===
Code: P1608 - FIP Watchdog signal lost
Open Circuit
Signal shorted to ground or signal return.
Supply voltage to FIP out of range
FIP supply voltage
FIP
PCM
CAN communication fault
===END PCM DTC P1608===
===PCM DTC P1664===
FIP malfunction
PCM
FIP
===PCM DTC B2139===
Code: B2139 - The PCM identification was not recognized by the PATS module.
===END PCM DTC B2139===
===PCM DTC B1600===
Code: B1600 - At some time since last clear the ignition was switched on without any key code being read.
Run the PATS diagnostic
===END PCM DTC B1600===
===PCM DTC B2141===
Code: B2141 - There is no PCM identification known to the PATS module.
===END PCM DTC B2141===
===PCM DTC B2139===
===PCM DTC B2139===
===CSM DTC None===
Successful DTC reading, no error codes found
Module: Security module
===END CSM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
_Mcmoo_
Re: Transit Mk 6 flash 23, and error codes
Postby Altransit » Sun Oct 11, 2026 10:40 am
The first thing to check with a FWD TDDi is the wiring to the pump where it bends around the front of the engine (in the area ofthe starter motor). The copper wires can fracture, inside the PVC covering causing an internal break, due to tension in the wire, or scuffing on adjacent metal.
Checking involves taking the loom out of the outer sleeve, and checking each individual wire for fracturing :idea:
