Trickling noise
Trickling noise
Postby Aztran » Thu Nov 17, 2005 10:57 am
Marnin,
just changed my coolant for winter, no over heating, temp fine ect......but when engine is off, for a few minutes or so u can hear a trickling noise from the bottom area of the engine! Theres no water leakin out, just the noise....
Any ideas?
2000 x, new style Transit 350!
Aztran
Postby Smooth Hound » Thu Nov 17, 2005 1:07 pm
I could be wrong but think that's fairly normal, just any water settling down that's not been returned to tank. I'm sure someone who knows more than me will tell you if it's anything other than that.
Mike
Smooth Hound
trickling noise
Postby chrisvmax » Thu Nov 17, 2005 1:10 pm
Hi,
my 2.5 di also does this, always has.
Don't think it's a problem.
Regards,
Chris
chrisvmax
Postby madmark » Thu Nov 17, 2005 1:12 pm
you will probly find its were the oil and water are settleing down! :D
funny noise
Postby john leeman » Thu Nov 17, 2005 4:15 pm
don't worry heat transfer from your coolant, check level regulary.
35 years of driving,repairing,sleeping in transit's lovin every minute.
john leeman
Postby Nighthawk » Thu Nov 17, 2005 7:27 pm
My money is on the noise being the oil from the top end of the engine falling back to the sump.
Sometimes you become a little paranoid after doing a job yourself and you look and listen a little too hard :)
Nighthawk
Postby finnon » Thu Nov 17, 2005 9:21 pm
i thought it was oil when i first heard it aswellnever heard it on a petrol engine before so i was surprised when i heard it on the diesel tranny
finnon
Postby GMC » Thu Nov 17, 2005 11:37 pm
Sounds to me like 'Air' is the system !
When the engine is hot, release a jubilee clip slightly at the highest point of the engine, you should hear air leaking out. You may have to manoevre the hose slightly to break the seal. Once it stops hissing, and water comes out, thats it bled. Just tighten it up again !
GMC
Postby dan@dsfplumbing » Fri Nov 18, 2005 12:50 am
GMC wrote:Sounds to me like 'Air' is the system !
Correct !!!
(IMO)
Although breaking the system to bleed should hopefully be uneccesary. Fill the expansion tank right up to the top and give the engine a few revs. the air bubbles should come right out then. If you have constant air bubbles then take a deep breath and say... 'head gasket'
(IMO) i aint schumakers mechanic !!!!
dan@dsfplumbing
Postby Nighthawk » Fri Nov 18, 2005 11:26 pm
I'd doubt it being air in the cooling system tbh.
Both the raiadtor and the thermostat housing have degass pipes going back to the expansion tank, so trapped air shouldn't be a problem. If it was air in the system on a regular basis (i.e every shutdown) you'd notice excessive pressure in the expansion tank and most probably overheating too.
If your close enough to the sump on a di engine you will hear the oil dropping back after the engine has shut down.
Nighthawk
Postby dan@dsfplumbing » Fri Nov 18, 2005 11:32 pm
i didn't read the original topic proper !! i thought it was when the engine was revved.. soz
dan@dsfplumbing
