Nighthawk wrote:Can you give any other details on the van? An X plate can be one of two models.
I'm a little confused as to whats going on.
Thanks for your reply dude, What do you mean by TSB... something or another "service bulletin" I assume... Having had a look at the leak its not easy to determine where the leak is from, we all know how diesel can run up and all over the place so Im not sure where its comming from which is a bugger, Im just a bit concerned that it may not be worth repairing the solenoid leak and waste +£200, then spend another £700 on a pump, that alone means I could pick up a good lowish mileage engine complete, what would be the best way to determine if it is just the seal on the solenoid, if it is just the o ring would you know what the dimensions are, this is going to be a job Im going to tackle myself, is there any special tips I need to know, ie: remove starter motor etc, I will in the meantime order up a decent workshop manual for the Tranny.Nighthawk wrote:It's a repair covered by a TSB and even a recall on some of the later vans, book time is between 2.7 and 3.0 hours to replace it. It's a bitch of a job too.
If the leak is higher up than that, your looking at a repair by a pump specialist as Ford don't supply any other parts for the Bosch pumps.
